Chris NottAH Fabrications
    Jul 2011
    30
    Straight Light Issue
    I replaced the headlight bulbs in the A3 yesterday for some OSRAMs and since then I have noticed that when I have the light switch set to AUTO the lights never go off when I lock the car. I must lock, unlock and lock again for the lights to go off.
    If I go into the car and move the switch to off the lights do not turn off? However if I set it to off and then manually change to sidelights or headlights they function correctly.
    Does anyone have any ideas what might be wrong?
    The lights are on when its light and dark, I thought lights either work or do not?
    Aug 2012
    Milton Keynes
    86
    Are you sure your car has the light sensor?
    Also I have a habit of hitting "lock > unlock > lock" because I am a paranoid guy and dont want to stand for 30seconds. But the lights should go off after around 30seconds of locking. (so gives you light to get to your door step/security I guess).
    Try that. Other bit seems bit odd to be honest.
    Jul 2011
    30
    I cant seem to fix the spelling mistake in the topic. I have not waited 30 seconds but with the old bulbs the lights went out straight away when the car was locked.
    I will time and see if they go out after 30 seconds, I know when you remove the key the light switch does not work if you turn them to off as they remain on
    26,720
    Does your light switch have a small rectangular button at the bottom slightly to the left, under the main headlight switch dial.
  1. brake lights issue
    By dares_uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2009, 15:23
  2. Newbie with a strange interior light issue
    By PervyPete in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th April 2009, 12:09
  3. 54 plate A6 2.4V6 - number plate light issues
    By A6fella in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th October 2008, 19:45
  4. engine management light issues
    By ninjab in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2008, 00:20
  5. Airbag light issue
    By RobG1232000 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th April 2008, 20:22
