AH FabricationsChris Nott
    Aug 2012
    Chester
    Ignition start problem
    Hi guys been having trouble lately with my 2008 a3 170tdi seems to be ok starting from cold start but if been on a journey ie stop to get fuel it struggles to start again and will only start by rolling it has anyone had this problem ir no anything about it ? My guess is the starter motor
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    804
    Coolant temperature sensors do this if faulty, they send the wrong signal to the ecu and then it can't inject the right fuel/air mix.
    If you can get it scanned, i think a fault in the cooling system would show.
  1. HELP (STARTING PROBLEMS)!!!!
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2004, 20:13
  2. a4 starting problems
    By lazzaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th June 2004, 12:44
  3. 100 with starting problems
    By SaabManIan in forum Classic Audi Forum
    Last Post: 26th April 2004, 03:01
  4. 2.5TDi Starting Problems
    By aj_mackay1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd April 2004, 19:47
  5. 2.5TDi Starting Problems
    By aj_mackay1 in forum General Technical / How To
    Last Post: 22nd April 2004, 12:28
