Chris NottVolks Autos
    Sep 2011
    audi a3 01221 fault code help
    hi all, I have had a look through the forum but cant find any answers so I thought I would post a question, my a3 sportback s-line had the airbag light come on so I purchased a code reader from e-bay and it read the code as 01221 crash sensor side airbag drivers side I have located the sensor in the drivers door and changed it over with the passenger side one and reset the fault code the code would not clear and still showed the drivers side so a:- is the crash sensor ok, as I thought it would have transferred the code to the passenger side, b:- is it likely to be a broken wire in the loom, has anyone had this before, c:-any thing to check would be great as the missus don't like the idea of the airbag light on thanks in advance
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    In all fairness mate, those snap on readers are not the best or most accurate. Get someone with VCDS to give it a proper scan and then take it from there.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
  1. Replies: 3
    Last Post: 29th April 2013, 16:58
  2. 2002 audi cab fault codes help
    By bowmeat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2013, 18:19
  3. audi a3 8p 2.0 tdi 2004 fault codes, help!!!
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2012, 12:16
  4. Audi A4 Avant 1.8T Fault code help
    By Wilo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th May 2010, 19:27
  5. fault code help
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th June 2007, 23:43
