EM TuningChris Nott
Results 1 to 7 of 7
    Mar 2013
    West Yorksire
    26
    Glow plugs fault on VCDS
    Hi all Ever since I've owned my car I've been getting these faults via VCDS for the glowplugs and cleared them many times :
    17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
    P0671 - 000 - -
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Bin. Bits: 11000100
    Temperature: 8.1°C
    Bin. Bits: 10110000
    17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
    P0672 - 000 - -
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Bin. Bits: 11000100
    Temperature: 8.1°C
    Bin. Bits: 10110000
    17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
    P0673 - 000 - -
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Bin. Bits: 11000100
    Temperature: 8.1°C
    Bin. Bits: 10110000
    17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
    P0674 - 000 - -
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Bin. Bits: 11000100
    Temperature: 8.1°C
    Bin. Bits: 10110000
    I think its time to stop ignoring them and do something about them. Any advise on what to do ? shall I get them changed or tested for voltage . My mechanic mentioned a relay that could be gone but this was on the top of his head.
    Thanks all
    AudiMafia's Avatar
    Apr 2009
    London
    403
    Hi, If the car starts up fine when cold then you don't need to worry as it means nothing, had the same reading on my car for couple of years and it only cleared when i changed the EGR valve I don't know if it's got something to do with it or was a coincidence.
    A3 8P 2.0TDI 140 Sport | Blue | Full Leather Heated Seat | BOSE | 6 Disc Changer | None Smoking Pack | | Nav | Xenons |
    Mods | 18" Rotiform Staggered | Tinted Windows | S3 Spoiler | 2009 S-Line t Rear | Front Chin Spoiler | Wind Deflectors | Re-Map |
    | MY11 Lights | S3 Side Skirts | Private Number Plate | Milltek Exhaust | S Line Gear knob
    27,084
    That points to the injector loom which also houses the glowplug connections, so yes get it checked out as 1-2 to go yes possibly, but all 4 points to a common denominator, loom.
    Apr 2011
    20
    Hi I read that you were having a fault with all four of your glow plugs, i have this vcds error too and was wondering of you ever got it sorted?
    27,084
    Have you read the thread yet?
    Apr 2011
    20
    Yes I read the thread, you mentioned that it points to the loom?
    Am I being blind and imy2k mentioned that he resolved the problem somewhere?
    It doesn't seem to be effecting my driving quality at all and I never have a problem starting the car and so I was wondering if it was worth doing anything about it.
    27,084
    Its only relevant on diesels when the weather is cold, so it probably wont make any difference now, come winter it maybe an issue for you.
  1. 2.0 TDi BKD Electrical Fault on Glow Plug Cylinder 2 - Misfire smoke etc.
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st November 2012, 10:51
  2. Help!! ADVICE NEEDED Glow plug Electrical Fault
    By SID in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th October 2011, 12:57
  3. 170 TDI Glow Plug Relay Fault
    By PJLarge in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th January 2007, 08:22
  4. Glow Plug Relay for 170TDI - design fault?
    By southpaw66 in forum Diesel forum
    Last Post: 17th November 2006, 10:32
  5. 1996 A6 2.5 Tdi Quattro Estate Glow plug problem
    By mmarks in forum Diesel forum
    Last Post: 4th December 2003, 19:54
