Badger5JMB Retrofits
    Jun 2013
    25
    A3 Camchain AND Cambelt... What's the Deal?
    Sort-of jumping on the back of a previous thread here - S3 Camchain Failure...
    But, camchain and cambelt - which models does this apply to? I'm just about to get the cambelt, water pump and coolant changed on my 58k A3 2.0 Tdi Sport 140 and wonder if a camchain needs to be factored-in?
    I was under the impression that the chain lasted for intergalactic mileages anyway and see no mention of maintenance or replacement of the chain in the Haynes workshop manual. Is the dual chain/belt set-up specific to the S3 only, or a model-wide characteritsic?
    confused.com
    Jul 2013
    311
    To my knowledge with is typical procedure for most 16v Vw engines to drive one cam off the cambelt and have then on a chain between both cams I have heard of the tensioner failing but that won't do to much damage as the chain shouldn't be able to jump of it will just slap about
  1. What's the deal with Mercedes' "disco" fog lights?
    By benw123 in forum General Automotive Chat
    Last Post: 20th October 2010, 00:23
  2. Rear shock in facelift and pre , what is the difference?
    By kninio in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2007, 00:22
  3. Leasing - what's the deal?
    By stewarta13wsb in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th June 2006, 21:40
  4. Symphony and BOSE, what's the deal with the Volume!
    By Boyakasha in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th October 2005, 13:24
  5. V5 and V5C? What is the difference?
    By laurra in forum General Chat
    Last Post: 14th August 2005, 19:12
