Chris NottJMB Retrofits
    ARH
    Dec 2012
    117
    Rear wheel bearing replacement? Talk to me!
    I have a 55 plate (facelift) a3 1.6 FSI, the wheel bearings have gone so I went euro and got the whole hub with the bearings etc, but I just want to know how hard/easy it is?
    Any tips?
    Do I need to remove the big multi spline in the middle of the hub?
    Any help would be great as I am attempting it tomorrow!
    Aaron
    Jan 2011
    northants
    165
    remove caliper and pads
    remove discs
    undo centre nut and remove hub assy
    sorry cant remember torque setting for centre nut
    ARH
    Dec 2012
    117
    Is the multi spline a M16 or M18? I have just found a M16 spline bit which fits OK but not great, but I reckon I'll be able to get it off with a M16 spline bit?
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Make sure you have the correct spline socket - it has to be spot on otherwise it will slip and round off due to the amount of torque you are going to have to use to undo it.
    ARH
    Dec 2012
    117
    Ok mate no problem ill go buy one today.
    Could anyone tell me what torque settin the bolt is? My car is a 1.6 fsi 55 plate if that helps?
  1. Audi A3 rear Wheel bearing replacement Hard job ?
    By Dom29 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2013, 10:57
  2. rear wheel bearing replacement a3 18t
    By weelo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2012, 21:45
  3. A3 rear wheel bearing replacement queries...
    By richrich14 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2011, 21:40
  4. Rear Wheel Bearing replacement.
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th February 2010, 18:22
  5. Replacing rear wheel bearing
    By Leon in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2009, 14:47
