Chris NottEM Tuning
Results 1 to 39 of 39
Like Tree2Likes
  • 1 Post By H17YD L
  • 1 Post By H17YD L
Thread: My S3 Stage 2+ dyno
    Dec 2012
    244
    My S3 Stage 2+ dyno
    Thought i'd post up my graph from my dyno run. Was a 25-30 degree run and with the haldex disconnect (2WD dyno)
    In case you cant make it out its:
    337bhp @6257rpm
    364 ft/lb @3565rpm
    It's going back in to have the DSG map finished so will make a little bit more power as it will rev to 7100rpm. I wanted more power but this is at the limit of the S3 plastic end tank intercooler!
    Comments welcome!
    S88 YRS likes this.
    2010 Condor Grey S3 Sportback S-Tronic. 354bhp 414ft/lb.
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,481
    something isnt right there torque is higher than bhps? Normally you should see them to be simillar or less torque.
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    Dec 2012
    244
    You can have more torque than bhp. Look at most diesels.
    Or do you mean in the TFSI only? As I've seen it before where they have more torque than bhp
    Dean_T's Avatar
    May 2004
    West Mids
    523
    How well does it drive now?
    What stage did you got to 2+ from?
    Which map do you have on the car?
    Lots of questions lol
    Dean.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Quote Originally Posted by RedDejavu View Post
    It's not uncommon to see more torque than bhp,but what's more important is the torque curve is quite reasonable,and has no big midrange dips.
    Jan 2012
    474
    Who mapped it?
    Is it a Gen 4 Haldex S3 as I thought these could be run in 4WD mode?
    I didn't think the S3 intercoolers had plastic end-caps, only the Ed30/Cupra?
    What mods are you running?
    Even more questions ;-)
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Quote Originally Posted by nluk100 View Post
    Who mapped it?
    It's the dyno that was the issue I think if I'm right in thinking it was a 2WD dyno.
    Haldex systems DO cause problems with our cars when you try to run a lot of power,and the Haldex starts shifting torque around,causing the dyno to throw a bit of a wobbly,and we had problems putting mine on the dyno,and I know several others who had the same problems.
    The cure if it can be called one,is to run in 2WD mode by disabling the Haldex.
    Dec 2012
    244
    Quote Originally Posted by Dean_T View Post
    The car drives really well, nice and progressive. But doesn't feel that fast because of how smooth it is, a look down at the speedo and you know it is goin quick lol
    It was standard to 2+. Previously had APR stage 1 then removed.
    Now running R-Tech custom
    Quote Originally Posted by S3Alex View Post
    Glad you have commented Alex, and glad you think it looks good! I wanted more power but seems I'll have to get a bigger intercooler.
    Who mapped it?
    Think it's Gen4. It's a 2010MY I didn't know about the intercoolers till I took it in! Seems Vag made them all plastic end caps after 2009 (tight b4stards!!)
    Mods are: custom 3" downpipe de-cat, milltek non res cat-back, autotech internals, neuspeed p-flo, PCV removed and catch can fitted.
    S3Alex likes this.
    Dec 2012
    244
    Yeh it was a 2wd dyno and run by disconnecting Haldex plug.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Quote Originally Posted by H17YD L View Post
    By all accounts,it's actually not bad,and if you want more power,and possibly torque,you'll need an uprated HPFP,which will help things a bit.
    The biggest limitation is the turbo,which frankly will run out of puff at around 360-370bhp.
    If you want a big intercooler,then you have a good choice now,with Airtec,THS,APR etc,and ProAlloy,which is still probably the biggest one you can fit.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    It's not the ideal way of getting a run,but if that's all they have,then it's what you get.
    We tried a set of 2WD runs on mine as the dyno was getting seriously upset by the power and torque shifts,and it helps to use 2WD under those conditions sometimes.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    E
    337bhp @6257rpm
    364 ft/lb @3565rpm
    Comments welcome!
    Mine isn't an s3 but on a 4wd dyno it made 260bhp and 279 torque. Think it's normal? S3 stage 2 before me made 334bhp so well done sounds like a good map
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Dec 2012
    244
    Got the HPFP done Alex, autotech internals.
    There is a good choice now and like to look of the Airtec.
    Read a few times now that its safer to run in 2wd for the reasons u mentioned
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    OK...didn't know you'd had the HPFP done,which would explain the good midrange torque.
    I think the generally accepted reasoning is to use 4WD if possible,and to use 2WD only if either the tuner only has a 2WD dyno,or the Haldex is causing problems.
    For instance,mine ran absolutely fine on the RR until we got beyond 400bhp.
    Jul 2011
    217
    Is 337 bhp not a bit low for stage 2+ ?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Quote Originally Posted by jonny1985 View Post
    Perhaps,but don't forget the general dyno lottery,plus 2WD running,plus 25-30C ambients and stock intercooler,where heatsoak can make a difference.
    I'd be happier with the torque,than being concerned about peak bhp,and once the car adapts,there may be a bit more.
    Jul 2011
    217
    Ah. Thourt the stock ic was able to cope with stage 2+ pretty well. Also though stage 2+ was closer to 360 bhp
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Like I said.....you have to allow a bit for RR variability,plus take into account the ambient temps.
    If you do a run on a stone cold day,I can virtually guarantee better results than on a hot day,mid summer.
    Jul 2011
    217
    Yeh its better when its cooler. Looks like he has used Rtech the same as me . It was freezing when mine was mapped lol so that's why probs made more lol
    Feb 2011
    Plymouth
    1,146
    Pretty sure r tech's stage 2+ isn't the same as revo's stage 2+ therefore figures won't be the same.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,292
    I've been qouted 310bhp from a stage 1 remap on 8p s3... thats with shark performance... these figures sound right?
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,292
    Quote Originally Posted by S3_Jacko View Post
    And will all the standard bits hold up to the extra bhp and torque... i.e turbo, clutch... engine as a whole, without any mods?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    The S3's manual clutch is pretty poor,and wil last till about 310-330lbs at best.
    The stock K04 turbo will get you to about 360-370bhp,and then it's maxed out.
    Other than that,the engine is good for 440lbs without any internal mods.
    Above that,you need new pistons,rods and a shedload of other bits.
    Dec 2012
    244
    What mods do you have? What figures did u get?
    the alluminuim end tank I/c will cope with more but mines got plastic end tanks. Hopefully bigger one on soon!
    Quote Originally Posted by smurfworth View Post
    Who said it would be??
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    I think one problem is different tuners calling their stages different names,for instance Shark's Stg3 is Revo's Stg2+ etc.
    Also,whilst they all get approximately similar figires,they won't be exactly the same,and even the same software on 2 diffferent cars may give different figures,especially if the boost and timing are slightly different.
    Jul 2011
    217
    Mine made 302bhp and 356 ft lb of torque with no mods on a stage 1
  28. #27
    Dec 2012
    244
    I know that different companies use the different levels. But I have the mods to support the equivalent of revo stage 2+ and is mapped for said mods.
    Daft for someone to say the figures will different to revo. As we all know they will and like you say the same map can be different on 2 cars. It's all down to the car, hence the reason I wanted a custom map.
    Seems R-tech go for torque over HP. Makes a really nice drive! What year is your car?
  29. #28
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    My S3 manual made 345bhp and 358lb-ft at stage 2+ (revo) but them figures were on the standard clutch with it slipping through the rev range. Now I've got the loba/Sachs clutch kit fitted and bedded in I need to get it on a dyno.
    The mods I had on the car were:
    ITG Maxogen induction kit
    Milltek full system
    Auto tech internals
    Up rated dump valve (Audi's)
    Airtec intercooler
    I then got the loba/Sachs clutch kit.
    Wasnt sure how the slipping clutch would affect the power outputs on the paper, if it would make them less or more, but I suppose only getting it RR'd again will tell.
  30. #29
    Dec 2012
    244
    How do you rate the Airtec? Have you done any logging to see how good it is?
  31. #30
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    I can't give you any information on the Airtec unfortunately,but I can on the ProAlloy I have on mine.
    This will give intake temps within 10-12C of ambient with boost up to 2 bar,which I thought was pretty good....the others such as the Airtec/THS/APR etc should do a lot better than the stock one which develops hotspots under heavy load/high boost,and doesn't perform so well under those conditions.
  32. #31
    Jul 2011
    217
    2009 (59)
  33. #32
    Dec 2012
    244
    Dont suppose you know if your intercooler is the newer style with plastic end tanks?
  34. #33
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Haven't done any logging, but went to Germany (nurburgring) last year with it (stage1) and just got back from France/Switzerland/Italy, with it on and at stage 2+ and not once did it skip a beat. It pulled hard through all gears. Whereas at the nurburgring it felt like it tailed off a bit.
    Although I think my fan is on a lot more now.... Hahaha
  35. #34
    Dec 2012
    244
    I envy you doing all that driving across Europe. I've said I'm going to do it every year for the the last 5 lol! I'll plan it for next year
    Thanks for the review of the cooler! Seems the cheapest quality cooler I can get, we'll the THS is only £70 more but the Airtec has a thicker core I believe.
  36. #35
    Jul 2013
    104
    Quote Originally Posted by DJ-S3 View Post
    Milltek full system
    Auto tech internals
    Airtec intercooler
    When you say bedded in, what do you mean exactly? I had a sachs/loba upgrade a week or two ago at AmD Tuning in Essex and they told me that it didn't need bedding in.
  37. #36
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Quote Originally Posted by T3KT0N1K View Post
    Yeah statller told me the same. But couldn't do any harm to not thrash it for a few hundred miles.
  38. #37
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Yeah it was loads of fun. Both of them. The nurburgring trip wasn't just there, went to Amsterdam/Bruges/Brussels/cologne and Mannheim (German GP).
  39. #38
    Dec 2012
    244
    Fantastic mate! Need to do it, and especially in the S3
  40. #39
    turbonutz's Avatar
    Jul 2013
    Glasgow
    400
    Dont need to change anything with stage one map. I have stage one the now and pretty standard the now with plans of pushing it bit more. To got beyond that you might want to change things to help supply support for power like CAI down pipe HPFP? Then beyound that stage 2+/3 you may need to change parts like clutch to support power from what ive gatherd. Personally about stage two id want to change breaks before going further as I recon you should have better more reliable stopping power with increase of actual going power haha just a para thought maybe eh?
  1. 3.0 tdi quattro Sodex Performance Stage 1 Dyno
    By harra1979 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 4th June 2013, 21:40
  2. Audi S7 Needed for Stage 1 Preliminary Dyno!
    By Evan@APR in forum A7/S7 forum
    Last Post: 8th March 2013, 14:07
  3. My Stock Vs. Stage 1 (APR) S3 on the Dyno
    By Aviry in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2012, 16:14
  4. Dyno Plot - REVO Stage 2+ on a Seat Leon Cupra K1!!
    By AwesomeMike in forum Awesome GTI
    Last Post: 20th October 2010, 15:21
  5. Revo Stage 2+ / Dyno Dynamics RR results ?
    By Spin140 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th January 2010, 20:58
