EM TuningSky Insurance
    Mar 2013
    West Yorksire
    26
    Coolant leak again . Video included
    Hi all. The coolant on my TDI has started too leak again . I only had the mechanic fit a new timing belt and waterpump a few months ago and it seems like its leaking from that area again and the sound of the engine had changed. A friend mentioned i should change the alternator pully as there seems to be alot of vibration around that area could this be the reason the water pump has gone again. Any advise would be great before i take it back to the garage tomorrow
    please find the video link below
    F8309F4D-185B-4FC5-B7D1-154C8ACCC10B-727-000000D5A901B566_zpsacaee1b1.mp4 Video by imy2k | Photobucket
    thanks all
    tdi-man's Avatar
    Jul 2009
    1,611
    take it back under warrenty....
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Mar 2013
    West Yorksire
    26
    Thats what I'm going to do . Just odd how it went so soon i paid for a good quality part too
  1. Coolant leak
    By petewon in forum General Technical / How To
    Last Post: 5th October 2006, 21:33
  2. Problems with S3, suspect coolant leak & Turbo dump/recirc Valve noise??
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 17:17
  3. 2.0 TDi Coolant loss <again> - Get it checked out!!
    By adamhill in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2006, 16:20
  4. coolant leak - need to id name of pipe
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2006, 01:03
  5. Possible coolant leak, any ideas?
    By jgrand in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2005, 11:46
