Chris NottMonster Motorsport
Results 1 to 9 of 9
    slizza786's Avatar
    Aug 2013
    123
    Help replacing headlights
    Hi
    I have an Audi A3 (04 plate) 2.0 TDi with fog lights and want to change the halogen lights to some super white halogen ones. Iv found a full kit which includes the main beams, side lights, dipped beams and fogs. The problem im having is fitting them onto the car because i wont be spending £7.99 on each bulb at halfords to fit them on. If someone who knows how to change them wouldn't mind sharing some knowledge i would really appreciate it.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,927
    really ?
    you take the back cover off remove old bulbs
    refit new bulbs and place cover back on
    if you cant do this then take it to a garage and pay to have them fitted
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    It isn't difficult, just very fiddly to get your hands in. My word of advice would be to find someone with small hands and if you can't, get some long nose pliers, it'll make the job a lot easier.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    slizza786's Avatar
    Aug 2013
    123
    Thanks for the response guys. Iv attached some photos here hopefully to show where im getting the trouble from.
    for this part i dont know what is keeping the bulb in place i cant seem to find the correct hook to release, has it got something to do with that metal ring?
    As for the main beam I didnt want to risk moving it around until I know which part to undo. Where do I start off?
    Finally for the fog lights is there a specific part when I have to pull to release it off the bumper?
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    With the main and dipped beam you just pull the socket with the bulb out.
    Fog lights - if I remember correctly you can pull out the grilles to have easier access to the rear or could also unscrew them after removing grilles.
    VCDS USER
    slizza786's Avatar
    Aug 2013
    123
    Quote Originally Posted by SAiLO View Post
    thanks guys im going to try this out and see how it goes
    slizza786's Avatar
    Aug 2013
    123
    With the high beams I was able to pull it out of the socket and take the bulb out. However I'm still finding it hard to come in contact with the main beams because if the black box blocking it
    slizza786's Avatar
    Aug 2013
    123
    ignore that last post just found the clip to release the cover if this box
    bez101's Avatar
    Jul 2008
    7,927
    good find your big red arrow is pointing to it
  1. Help - Xenon Headlight Failure
    By X_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2009, 01:03
  2. urgent help fitting headlights
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st March 2006, 14:03
  3. Replacing headlight glass on A3
    By AndyMac in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2004, 22:12
  4. Replacement Headlight - Halogen
    By imported_Tariq in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2004, 21:36
  5. Hellfords replacement headlight bulbs
    By ActionJackson in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd May 2004, 07:11
