Chris NottEM Tuning
    Jul 2012
    Shropshire
    32
    Juddering A3 Help please!
    2005 A3 2.0 TDi Auto (BKD 109,000 miles)
    Ok so my car has suddenly started to develop a very noticeable judder when cold at around 1,700rpm. It feels like fuel starvation, raising the rpm will instantly cure the problem - and it disappears completely when the engine is up to temp.
    VCDS shows the only known problem the car has is a worn glow plug harness which occasionally throws an eml and makes the car slightly grumpy on cold winter mornings - but it always starts. The second problem is the coolant temp sensor on the radiator, that has a mind of its own. However the engine coolant sensor seems to overrule the faulty rad sensor and the car always displays the correct temp.
    But the above issues are old and I just live with them, the engine harness is a nightmare to change and the engine temp sensor works fine. So what's causing this new juddering that literally rocks me back and forth!?
    Thats for all your help and advice
    ps. New fuel filter 12,000 miles ago, redex very occasionally used, never use supermarket diesel. Could it be the egr?!
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,292
    Spark plugs, pcv, maf
    Aug 2009
    833
    Quote Originally Posted by S3_Jacko View Post
    on a diesel?
    Jul 2012
    Shropshire
    32
    Quote Originally Posted by Nutkin View Post
    on a diesel?
    Yeah I think he must have forgotten I had a TDi......
    However I suppose i should really check the MAF, but what's the pcv?!
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,406
    Follow Brodster On Twitter Add Brodster on Facebook
    Check the fuel filter again and check to see if the cannister has oil in it. If it has then thats your problem with the kangaroo'ing. The tandem fuel pump seals breaking up allows oil to seep into the fuel so get that checked out too.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
  1. A3 2.0 TDI Juddering HELP PLEASE
    By nick4575 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2013, 20:08
  2. 05 Audi a4 2.0tdi s line, hard juddering at high revs. HELP PLEASE
    By vavavag in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th September 2012, 13:57
  3. 2006 A3 2.0 TDI 140 judder/hesitate under 2k problem.. Help please.
    By jon_s in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th May 2012, 17:26
  4. still got brake judder...dont know what to do next.. help please
    By mar1b0ro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2011, 01:05
  5. I.T. help please!
    By MisterD in forum General Chat
    Last Post: 20th January 2003, 21:19
