EM TuningMonster Motorsport
Results 1 to 1 of 1
    Mar 2013
    21
    Tyre size for 18x8.5 alloys...
    I have purchased a set of second hand replica alloys as pictured, they are 18x8.5 with an offset of ET38, I trialed the wheels on the car just to make sure they did go on without rubbing or catching anything and to also check they didn't stick out too far...
    My question is do I run 225/40 18 tyres or 215/40 18 tyres? Especially on the front.
    Being 8.5 wide would the tyres have a little stretch at 225 to be ok without fouling anything?
    The car is a 3dr A3 tdi S-Line on standard suspension at present, I will be looking at lowering it slightly soon though, probably on 20-30mm though.
    Any advise much appreciated,
    Cheers Paul
  1. Tyre sizes for a 8J Alloy
    By AndyT_uk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2013, 16:15
  2. Recommended tyre size for B6 S4 Alloys
    By A4 quattro in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th March 2010, 22:06
  3. Recommended tyre size for 18"/19"
    By mjepson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2006, 05:57
  4. Tyre size for 18" rim
    By Phlipper1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2006, 13:59
  5. A8 alloys - Tyre size for A3T?
    By geordiea3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2005, 12:27
