JMB RetrofitsBadger5
Results 1 to 8 of 8
    Dec 2010
    S3 S-Tronic gearbox over revving problems ?
    Hi everyone, I picked up my S3 last week. I'm now experiencing what could be problems with the S-tronic gearbox. Over the last few days I've become aware of the revs meter on the dashboard seems to be over revving sometimes when I'm driving around 30mph, and it feels like the auto hasn't adjusted to the right gear setting for my speed.
    I've not had an automatic or S-tronic before, but I'm presuming there could be an intermittent fault?. I didn't notice this over revving the first few days of driving the car, but it's happening on a frequent basis now, and last night I was doing 80 on the motorway - again it was over revving for the speed I was travelling at, it felt like it was in the wrong gear. I had to slow my speed down for the gear setting to adjust it's self.
    Surely this can't be normal for an S-Tronic? I'm considering contacting Audi tomorrow to get it checked up, any advice would be appreciated.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    Seems a silly question, but you haven't got it in 'S' mode have you...?
    If not, whats the year of the car? If its an early model, mechatronics is way up there on the list...and not cheap at all.
    If you had it second hand, you may also find the gearbox is mapped.
    It Changes the ratios so for example it won't be in 6th gear at 35-ish mph!! (huge bonus if so).
    If mileage is high, make sure it has followed the service schedule properly.
    Otherwise get the adaptation reset.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Dec 2010
    It's a 62 plate which I got from my local Audi dealer. It's low mileage and fairly new car. No I've hardly used the S mode
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by audiboyuk View Post
    Chuck it back at them then, tell them to run diag on it and explain its holding onto the gears for too long.
    Im guessing the vibe your getting in 'D' mode, with it holding on to gears is similiar to the feeling you should just be getting in 'S' mode? As in 'S' mode you won't get sixth for a little while if your 'tearing it up'...
    Dec 2010
    I'm not sure, I've not used the S mode enough times to make a comparison. I'm just disappointed that there is something not right with the car.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    If anything, in D mode it changes gear early, as if it can't wait to get into 6th gear.
    DeanTTaylor's Avatar
    Nov 2012
    Canberra, Australia
    You might need to post a little more info mate, what revs? what gear? what speed does it all occur at? how far is your foot down?
    Jan 2012
    473
    Get someone who has driven an s-tronic car to drive yours and see what they think. If you've got your foot planted then it could be dropping gears using the kick-down feature (which is a PITA in my opinion). Best to drive the car in M mode and use the paddles - gives you back control of the gearbox then.
  1. multitronic gearbox possible problem
    By Beast200 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 9th July 2011, 18:10
  2. Multi-tronic gearbox issue - possible fix
    By samuelt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th April 2011, 13:09
  3. What gearbox and Possible Problem!
    By aadams1x in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2008, 13:10
  4. S-tronic gearbox on the A4
    By h5djr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st March 2008, 11:19
  5. Possible problem with Going-Fast aluminium mirrors
    By gtiglasgow in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th January 2007, 10:38
