EM TuningBadger5
Results 1 to 7 of 7
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    Speed display on DIS
    Hi.
    When I start my 2008 A3 sometimes the DIS shows the digital speed display and other times it shows one of the other menus (Street name, MPG etc).
    Is there any way I can set the DIS to show the speed display as default? Sick of having to press thru the menus every time I start the car?
    Also, I have Sat Nav installed, is there a way of having the Map showing as default rather than the destination input?
    Small things I know, but they annoy me! :-)
    Chris
    DomH's Avatar
    Jun 2013
    Leeds
    116
    Are you using the same key by any chance? I leave mine on the speed and it always starts up with the speed!
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    Quote Originally Posted by DomH View Post
    Yes always use the same key. I wonder if it is something to do with the Sat Nav as it nearly always starts up with the Street Name display.
    Jan 2012
    1,837
    Turn the compass off on your RNSE by pressing NAV then SETUP and looking for the option.
    Mine always defaults to the speed and my compass is turned off.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    Quote Originally Posted by a6-chris View Post
    Thanks for this. Should the map show first on the Sat Nav also instead of the Destination input with this option?
    Jan 2012
    1,837
    Nope, it will always show the address input screen if you switch it off with the nav map on on each startup.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    Cheers A6-Chris. Speed display now shows on startup - shame about the Nav map but suppose there's worse things in life to worry about :-)
  1. Stereo display on DIS
    By Martin82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2012, 21:36
  2. Digital Speed Display
    By lanky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th July 2011, 13:21
  3. No sat nav display in DIS
    By Mini-mad-matt in forum Satellite Navigation
    Last Post: 26th September 2010, 22:16
  4. Flashing DSG gear display in DIS
    By dai-click in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2009, 19:17
  5. Stronic Gear display (without DIS) on A3 SE model?
    By mwardyrem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th December 2006, 10:12
