EM TuningJMB Retrofits
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By gen.heinz guderian
Thread: Anyone around Cambs that can do a VCDS DGS Adaption for me?
    jaydav2306's Avatar
    As the title says anyone thats real nifty with VCDS that can do this for me?
    2009/2010 | Audi S3 Black Edition Ibis White | Black Optics Pack | Fully Loaded | S-Tronic
    27,009
    What adaption are you referring to?
    jaydav2306's Avatar
    I've heard that it can be "reset" recently had a DSG oil and filter change and sometimes it's still a little jerky and I know that Audi will want silly money to do it
    27,009
    That should of been done when the dsg oil/filter was done.
    Sep 2012
    Prague, CZ
    88
    Quote Originally Posted by jaydav2306 View Post
    Actually mine feels jerky since having its DSG oil and filter changed - i have VCDS, can someone tell me how to check if it was reset? ... and how to reset it if required?
    2009 A3 TDI 170 STronic SLine
    Sep 2012
    Prague, CZ
    88
    All i could find on VCDS wiki was this:
    http://wiki.ross-tech.com/wiki/index...rbox_(DSG/02E)
    Jun 2011
    Great Melton Norfolk
    1,344
    just follow this procedure.Basic Setting
    Prerequisites:
    • Fluid Temperature 30...100 °C (86...210 °F), see Measuring Blocks, Group 019.
    • Selector Lever in P
    • Ignition ON
    • Engine ON (Idling) for one minute or more
    • Brake Pedal operated (hold for the whole procedure)
    • Throttle Pedal not operated
    NOTE: Be sure to perform the following steps in the sequence shown, followed by the defined test drive.[Select]
    [02 - Transmission]
    [Basic Settings - 04]
    BenC00 likes this.
    Sep 2012
    Prague, CZ
    88
    Quote Originally Posted by gen.heinz guderian View Post
    Prerequisites:
    • Ignition ON
    [02 - Transmission]
    Thanks... i'll give it a go and report back.
    27,009
    Hold up, remember the details on the wiki were for a dsg car, yours are stronic's, so check with ross-tech if the procedure is the same before acting upon, just to be safe.
    Sep 2012
    Prague, CZ
    88
    But VCDS Wiki only lists 2 gearboxes:
    Audi A3/S3 & A3 Cabriolet (8P) - Ross-Tech Wiki
    [02] - Transmission Electronics
    27,009
    Isn't your stronic 7 gear?
    If so then check with RT, I would still check with RT & also if your box is 09G, if not then again, check with RT.
    Sep 2012
    Prague, CZ
    88
    Thanks for your advice ... i just checked an old VCDS scan and my 6 Speed S-Tronic is type 'DSG/02E'
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 051 T HW: 02E 927 770 AJ
    Component: GSG DSG AG6 440 1963
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    A VCDS scan will tell you what box is fitted..i.e. This is of my car and shows it's a 02E box which follows RT file
    6-Speed Direct Shift Gearbox (DSG/02E) - Ross-Tech Wiki
    Part No SW: 02E 300 011 DC HW: 02E 927 770 AJ
    Component: GSG DSG AG6 440 1905
    Revision: 04844002 Serial number: 00000811271320
    Coding: 0000020
    Shop #: WSC 06314 000 00000
    VCID: 53AEE47FF2EE69B
    No fault code found.
  1. Anyone near Birmingham that can retrofit my Audi Bluetooth??????
    By oneniner in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th December 2013, 03:26
  2. Anyone in or around Hertfordshire that can code my cd changer to my RNS-E please?
    By Az in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th August 2011, 20:15
  3. Replies: 1
    Last Post: 19th July 2009, 11:16
  4. Anyone in the Cheshire that can fit Xenons pls
    By StagsyA4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th March 2009, 14:12
