sobrien1990
Hi all having a bit of an issue with my A3.
its an 04 petrol 2.0l fsi
The problem.
Currently the engine light is on so i gave it a scan and it came up with three fault codes.
p1031 Intake manifold air control valve position sensor - specification not attained
p1032 Nitrogen oxides (NOx) sensor - signal too high
p1033 Nitrogen oxides (NOx) sensor - signal too low
ive only scanned it with a cheap ebay lead so don't trust the codes 100%
The car seems to be driving normally no noticeable loss of power or erratic rpm
however occasionally the car will loose all power and go into limp mode turn ignition off re start the car and the problem goes away.
could a fault with the intake valve be causing the nox sensor faults?
is it worth having the intake valve removed and cleaned or just replace it to rule it out ?
are the nox sensors easy to get to so i could give them a quick resistance check and check the wiring?
I would admit i haven't done that much research yet and don't know my way around the a3 too well yet hopefully one of you guys have come across the same or similar issue in the past
Thanks in advance
Sam
The problem.
Thanks in advance
Sam
