Volks AutosMonster Motorsport
    Aug 2013
    Portsmouth
    Erratic Revs, Kangarooing and Stalling when cold isn't normal... is it?
    Hi all,
    I am a new member on this forum but have been a guest reader for sometime. There look to be a lot of people who know their stuff so fingers crossed you will be able to point me in the right direction with regard to my little problem.... on my car. Its a 2006 A3 Sportback DSG 2.0 with around 66k miles
    Here goes - car has erratic revs when idling in neutral which sometimes involves a stall.....
    When driving forward or backward on tick over (i.e. in our home or work car parks) the revs can be erratic and the car can stall
    When ‘creeping’ in traffic (i.e. stop/go on idle revs/stop/go on idle revs) the revs can be erratic and the
    car can stall
    If we were to drive from cold and accelerate gently we notice the car ‘kangarooing’
    I have a video of the rev counter showing it being erratic and stalling (Audi A3 Erratic Revs / Kangarooing / Stalling - YouTube and Audi A3 / Erratic Revs / Stalling / Kangarooing - YouTube). Apologies for the 2nd video as it has my commentary of whats happening. I promise I am not as boring as it sounds!
    This problem happens all year round (i.e. hot weather and cold weather) but is getting more frequent.
    It doesn’t happen every time (but is most)
    The best way to re-create is to start the car from cold then drive it on its idle speed. The 2nd best way is to just have the car idling and sometimes is happens.
    When the problem happens the engine management light doesn’t come on, the car just stalls
    This doesn’t happen when the car is at normal running temperature
    Its recently had the gearbox oil changed & full service at Audi Southampton (and brake pads changed at local garage). The local expert garage has said its a speed sensor problem in the mechatronic? and needs replacing at a cost of around £2.2k. Sounds expensive (and no guarantees that this will fix).
    Its a good garage that has a decent reputation but I am not going to part with that type of money without asking for advise first.
    Any suggestions/ideas?
    Crispin
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    ​Hi Crispin, welcome to audi-sport.net. You will get lots of help and advice in here. Have a read at the faqs threads at the top of this section, lots of useful info in there. Enjoy the forum, x
    Aug 2013
    Portsmouth
    Thanks Sandra, will have a read of the FAQ's.
    C
  1. Engine stalling when cold
    By OldRedEyes in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2012, 13:08
  2. My A3 stalls when cold, fine when warmed up - Urgent help needed
    By stephanbegley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2011, 17:30
  3. Engine revs up and down when coasting?
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th March 2011, 20:57
  4. Erratic revs when starting up
    By Dan Yeates in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2008, 12:35
  5. Engine Management Lights On... Stall's when cold.
    By kaz219 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th July 2008, 02:15
Tags for this Thread
