JMB RetrofitsAH Fabrications
Results 1 to 8 of 8
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    Wiper judder driving me insane!
    Guys, I really need your help. I started getting juddering wipers on my 2012 S3 a while back so I took it to the dealers. They kinda said its not covered by warranty but agreed to replace the wipers. Anyway a few hundred miles later and it started again. I thought it might be something to do with a rain repelling product I used (can't remember which one) so I used fairy washing up liquid, autoglym glass polish then several cleans with fast glass. Still the same so I eventually decided to repeat the process and replace the wipers with some brand new Bosch twin blades. Guess what, a few days later and it's back!!! It actually making me think about getting rid of the car!! Does anyone else get this or more importantly, resolved it? Can the pressure of the wiper arms be charged?
    Any help would be welcome. Admittedly not a huge problem compared to some but very very frustrating!!
    Cheers, Chris.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    My drivers wiper blade, especially the far right of the blade( if your sat in the car) wobbles.
    Drives me nuts, but haven't bothered changing it yet... cars done 20k ish with them so don't see it being too bad.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Loosen or tighten the bolt attaching the wiper arm to the linkage and see if it makes it worse or cures it.
    I would have suggested new wipers but you have said they have been changed.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Rain repellant products in my opinion are a pain in the butt. It's probably that what's causing the problem..
    Apply more of it, to see if that cures the judder or better still stop using it and try several applications of Halfords Intensive Glass Cutter 250ml.
    Halfords | Halfords Intensive Glass Cutter 250ml
    turbonutz's Avatar
    Jul 2013
    Glasgow
    400
    wiper arms been took off anytime and maybe not re-attached correct angle? guy tht changed my windscreen a wee bit ago asked to check this with sitting with them on for a wee couple mins.
    dan77's Avatar
    dan77
    Dec 2008
    Down south,
    195
    Mine does this after applying rain ex, I think the benefits of rain ex out weigh a bit noise from the wipers, not been doing it for so It might start winding me up sooner or later,
    A3 1.8T sport, revo stage 1, Forge 007, Green cotton panel filter, TTpedals. . . . . SOLD
    Golf GTTDI 130 . . . . . SOLD
    Current 2006 A3 2.0TDI Quattro S-Line, Revo stage one, chrome pedals, black grill, full interior and number plate LEDs retro fitted cruise control,
    Boon's Avatar
    Sep 2012
    South East Kent
    428
    The wiper blade needs to be at or very close to 90deg to the glass, if it isn't just bend/twist the arm so that they are at 90deg.
    You won't need to twist them much, even by hand often sorts them out
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    Cheers guys. I only ever applied the repellant once so thought I'd have gotten rid if it with extensive glass polishing. Maybe not.
    I'll try and twist the arm slightly and see if that works. The arms have never been removed as far as I know.
    Even with these new blades the bottom of the drivers side blade rattles about the screen as if its hardly touching it.
    PITA
  1. Help me fix this 1.8t that is driving me insane!
    By Lingo89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2012, 17:37
  2. Changing Thermostat on AMK, driving me insane!!!
    By beanoir in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2011, 14:55
  3. Squeeking Rear Suspension driving me insane!
    By V.I.P_UAE in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2009, 23:47
  4. Any ideas how to stop my front wipers from juddering??
    By robbie5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th April 2008, 13:55
  5. What causes windscreen wiper judder ?
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th October 2007, 08:24
