Results 1 to 7 of 7
    Oct 2012
    Reading
    Audi A3 Radio Help Please
    Hi i have a 2004 (53) plate audi a3 that had a single din standard audi stereo in, I've since then got myself a audi navigation plus (G) edition and all was fine all i had to do was buy a adaptor from e-bay so all was fine, or so i thought quite recently my car battery has been dying and this has only ever happened since the stereo was installed i have a 6 month old audi s3 battery so i know there is no problems with that. what i have noticed is even tho when i turn the car off and take the key out the stereo turns itself off....... but the fan for the stereo still comes on and off every couple of mins while its off. also if u press the botton on the stereo it will turn back on without needing the key..... can someone help? i think its something to do with the radio still getting power for the fan to turn on even tho its off. can some help please?
    thanks
    27,123
    It will still work with key out if you press the on button, also the fan & dvd drive do still run after ignition turned of, that's normal.
    Has it been coded, have you removed unit & then see if battery still goes flat?
    Oct 2012
    Reading
    the unit works fine i have now removed the wires for it so no navigation for me misses is currently using the car n she says its fine also i have sat in the car for over a hour after removing key n still heard the fan turn on and off is that normal?
    Oct 2012
    Reading
    right misses has been using the car all day so far and she said since the stereo was disconnected it starts without any probs
    p.s there was no coding done? it was plug n play except for entering the code for the actual stereo
    27,123
    You should code it & make sure wiring all in place, we offer these services.
    Oct 2012
    Reading
    how much would that be? i also had a flat bottom dsg steering wheel added but for some reason the volume botton and song change botton wont work
    27,123
    Best too give me a ring, I'll PM my number.
  1. K04 Conversion On Audi A3 AGU HELP PLEASE !!!
    By Chester999 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th October 2012, 11:36
  2. Safe mode on my radio ??. Help please
    By ayr_audi_nut in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd March 2012, 10:07
  3. Audi a3 suspension HELP?? please
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2010, 21:50
  4. Standard Audi a3 radio help
    By chol in forum In-Car Entertainment
    Last Post: 3rd September 2009, 20:25
  5. audi a4 2003 help please
    By ngoncalo in forum General Technical / How To
    Last Post: 16th July 2007, 04:05
