Badger5EM Tuning
Like Tree1Likes
  • 1 Post By NHN
Thread: 256 mg SD Cards
    Going Gone Bye
    May 2013
    Stroud, Gloucestershire
    32
    256 mg SD Cards
    Hi All
    I have a mark/series 1 RSNE MMI satnav system
    The manual says that you can only put a 256mg SD card (twin slot) in each slot
    Is it possable to put a bigger SD card into it and would it read a bigger card ?
    In an ideal world I would like to add two 4gig SD card
    Has anybody have any experiance of adding bigger SD cards/
    I have tried searching the subject, but no luck with the resaults
    Thanks in advance :-)
    27,099
    Yes you can put upto 4GB in each slot, but there is a limitation of how many files can be put on the cards of 400-512.
    If you wanted more with the ability to have thousands using SDHC cards, then the mk2 unit is the one to have, which gives you better res screen, sdhc compatibility, faster cpu, AMI compatibility.
    We supply/fit the mk2 series if interested.
    KrAzY K likes this.
    Going Gone Bye
    May 2013
    32
    Thanks NHN for your comment
    At least I can order bigger cards now
    Can you PM a price on the Mk2 replacement and location
    Thanks again
    27,099
    Will do now & I can come to you
    Going Gone Bye
    May 2013
    32
    Thanks for your PM.....sounds good
    Can I use SDHC cards or do they have to be the older SC cards
    27,099
    On mk1 units its SD cards only.
  1. How do you take a door card off?
    By imported_Tariq in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th September 2004, 19:41
  2. Door cards.....What a pain in the butt...!!
    By mdoyle69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2004, 16:24
  3. Are pre 2001 door cards the same as >2001 in a 3dr
    By kazino21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2004, 10:12
  4. Removing Door Cards
    By DamoS3Q in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2004, 13:41
  5. Removing door card on Polo
    By Naresh in forum General Technical / How To
    Last Post: 10th November 2003, 14:59
