AH FabricationsBadger5
    A3 SportBack 2TFSI quattro DSG
    Jul 2009
    Norway
    227
    Torque setting front axle bolt on quattro?
    Hi.
    Can some one help me get the correct torque setting on the front axle bolt? (centre bolt 24mm)
    Have read somewhere that it is 70NM + 90degrees
    Cant find this info again.
    Best regards
    J$B
    Norway
    Jul 2009
    Norway
    227
    Oh! I found it. Thanks to google.
    It is 70nm (car in the air) then 90degrees.
    this is the bolt.
    Sorry for double posting.
    Best regards
    J$B
    Norway
    27,099
    Which bolt exactly, any pics?
    27,099
    Yeap its 70nm plus 90 degrees when on the floor.
  1. Front hub nut torque setting
    By dusty in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2012, 18:38
  2. torque setting needed front hub nut
    By vr6gordy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th August 2011, 08:21
  3. Torque setting for crankshaft main bearing caps + crank pulley bolt please?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2010, 20:15
  4. Torque setting for cam cover bolts?
    By ButcherV6 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2010, 14:24
  5. Front hub bolt torque figure, S3
    By woody1302 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2007, 11:43
