Monster MotorsportChris Nott
Results 1 to 18 of 18
    tdi-man's Avatar
    Jul 2009
    1,587
    OIL CATCH CAN FITTED TO BKD ENGINE
    just fiited oil catch can to my engine...
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    Jun 2013
    17
    I nearly did this to my Golf then decided against it (More like couldn't get the hoses to fit).
    Looks good though.
    tdi-man's Avatar
    Jul 2009
    1,587
    I used 19mm internal diameter pipe into a 22mm joiner and then I 19mm to 13mm reducer pipe to
    my 15mm catch can.
    19mm pipe just pushes on the crank case outlet and other 19mm pipe pushes into genuine. Pipe
    Aug 2012
    60
    liking this mod! what turbo you running if you don't mind me asking?
    tdi-man's Avatar
    Jul 2009
    1,587
    Turbo techies hybrid.
    Will put more pics up tomorrow of pipe connection
    tdi-man's Avatar
    Jul 2009
    1,587
    using 19mm internal pipe at the moment but may get some 16mm internal dia so can remove joins.
    Oct 2012
    Warrington, North West
    955
    Where did you get then can from mate?
    tdi-man's Avatar
    Jul 2009
    1,587
    Oil Catch Can Black Round Universal Breather Tank CRANK CASE 15mm Fittings R | eBay
    u need one with 15mm outlets for a turbo . all works fine no running probelms with it fitted .
    Quote Originally Posted by Mikemc View Post
    TDI140's Avatar
    May 2011
    1,293
    Nearly as nice as mine lol ;-) ahha
    nah good work mate
    A3 2.0TDI FWD sportback with GT1756 225bhp 351ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch
    tdi-man's Avatar
    Jul 2009
    1,587
    thanks not happy with it at the mo so work in progress...
    does the job.....
    thanks
    TDI140's Avatar
    May 2011
    1,293
    I want to make some sort of bracket for mine i dont like using crappy cable ties although they hold it well
    A3 2.0 tdi s line 170
    Jun 2013
    Kent / london
    58
    Can someone explain the advantages of having this, I'm hopefully going hybrid soon and this seems like a cheap mod?
    TDI140's Avatar
    May 2011
    1,293
    It cost me about £160 ish as i had full silicone hoses made in red
    its stops oil going i to the intake which ends up in the turbo inlet which is bad
    also stops the oil from there then reaching intercooler hoses and trust me it works ive had mine for about 8 months ive empties a full load and its about 1/5th the way full
    tdi-man's Avatar
    Jul 2009
    1,587
    didnt want to go down the line of getting hoses made so bought the below.
    oil catch can - £23.00
    tie wraps - £2.00
    silconhose joiners -£10.00
    silcon hose reducers - 10.00
    silcon hoses - £10.00
    Jun 2013
    Kent / london
    58
    Why doesn't it come as standard?
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Quote Originally Posted by Tomwebb View Post
    Because the standard system is designed to be maintenance free, whereas this method will require you to monitor it and empty it when full. The average motorist isn't going to want to do this, or even know how to.
    I'm sort of tempted, but the new common rail engine hasn't used a single drop of oil. Unlike my old BKD A3 which needed topping up regularly.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    Aug 2010
    157
    has anyone installed the provent 200?
    TDI140's Avatar
    May 2011
    1,293
    Because most people here dont really have a clue what it does so if they dont know i doubt they will empty it so not worth the hassle by audi also
  1. where to fit oil catch can
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th July 2013, 23:10
  2. Oil catch can on 2.0TDi BKD
    By Boon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th February 2013, 12:30
  3. oil catch can fitted diffrenty to the norm??
    By frank s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2011, 06:34
  4. Forge Oil catch can -S3 - Group buy ?
    By Whiteatom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2010, 12:32
  5. BSH CATCH CAN FITTED TODAY.
    By G"MAN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2009, 18:46
