It cost me about £160 ish as i had full silicone hoses made in red
its stops oil going i to the intake which ends up in the turbo inlet which is bad
also stops the oil from there then reaching intercooler hoses and trust me it works ive had mine for about 8 months ive empties a full load and its about 1/5th the way full
Because the standard system is designed to be maintenance free, whereas this method will require you to monitor it and empty it when full. The average motorist isn't going to want to do this, or even know how to.
I'm sort of tempted, but the new common rail engine hasn't used a single drop of oil. Unlike my old BKD A3 which needed topping up regularly.
