AH FabricationsChris Nott
Results 1 to 16 of 16
Like Tree3Likes
  • 1 Post By Walts2782
  • 2 Post By bennymac
Thread: Unkown rattle
    Apr 2013
    Chipping Norton
    49
    Unkown rattle
    Hi I have a 2006 S Line 3 door with 97,000 Miles, since picked up the car there has been a metallic rattle which is quite loud from underneath the car. It occurs when going over rough ground and bumps. Jacked car on axle stands today and nothing is loose underneath (heat shields, brackets etc.). It is like a 'tingling'/hollow sound as if something is loose. Has anyone had this problem as I would like to get to the bottom of it...i have people looking around when driving past. It sounds as if coming from the rear of the car.
    Apr 2013
    Chipping Norton
    49
    I will try get a video this evening of the noise
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,202
    Follow Brodster On Twitter Add Brodster on Facebook
    Could it be the internals of the cat breaking up and rattling away......have seen that before but not on an Audi.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/VCDS/Wagner
    Apr 2013
    Chipping Norton
    49
    DomH's Avatar
    Jun 2013
    Leeds
    104
    Brake disc backing plate? They do tend to come loose and flap around
    Apr 2013
    Chipping Norton
    49
    I had a play with that and all tight, checked as much as i could on axel stands underneath and nothing making that loose rattling sound i could find, can't have a clue what it could be
    DomH's Avatar
    Jun 2013
    Leeds
    104
    Very strange! Sounds exactly like a backing plate to me, did you manage to check the coil springs too?
    Apr 2013
    Chipping Norton
    49
    Ill have a closer look tomorrow at the backing plate...as for the springs I have fitted coilovers last week and nothing untoward showed up. Had noise before and after
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    302
    I can't view the video unfortunately but check above the back box there is heat shielding that sounds metallicy when loose.
    Jul 2013
    12
    Did you ever find the problem with this ? I have quite a big rattle going over bumps and its not any of the heatshields or backplates. sounds like a bag of spanners are in the boot lol
    Nov 2012
    East Yorkshire
    206
    Check a coil spring hasn't broken off just a little and its sat just in the arm of the suspension. If the noise is from the rear I'd certainly give that a look but it'll need jacking up or a nice garage that will put it on a ramp for ya.
    good luck
    T33_BKD likes this.
    Audi A3 S-Line Sportback Black Edition
    White, 2009 2.0d 140bhp.
    DRL's, Xenons, RNSE, Bluetooth,
    to do
    Cruise, OEM Parking sensors, footwell lights, ambient light
    DomH's Avatar
    Jun 2013
    Leeds
    104
    Quote Originally Posted by bennymac View Post
    Check the rear shockers, there is a metal collar on the bump stop and they have a habit of working their way loose and rattling against the shocker
    T33_BKD's Avatar
    Browser
    Apr 2013
    London
    55
    Visit T33_BKD's Instagram Channel
    I had this exact problem on my 06 3dr s line, it was a piece of the coil spring which had broken off and was resting on the arm of the suspension (as mentioned). seems like alot of people had this issue so i'd start by checking there.
    Jul 2013
    12
    Well done troops took the rear wheel off and searched to find a lovely curly C laying in the suspension arm..... looks like a common fault across the range eh, ours is a 8p 3 door TFSI Quattro am I correct in thinking its lower as standard ? need to try some independents for spring prices now.
    Walts2782 and T33_BKD like this.
    Nov 2013
    Have just had exactly the same problem with my 56 plate S Line 2.0Tdi. Done just over 82,000 miles. Am waiting a quote from the local Audi dealer as I can't seem to get S Line springs from anyone else. Has anyone out there had any success getting these elsewhere or is it a search on EBay or Gumtree ?
    Nov 2012
    East Yorkshire
    206
    Bought a rear spring from audi parts for about £100 each, Local garage to fit here is £30 a corner.
    to do
  1. Rear roof rattle - SO annoying
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2003, 13:41
  2. Rattle on acceleration, occasional exhaust pop.
    Last Post: 2nd September 2003, 09:46
  3. Who's had the wet exhaust rattle modification?
    By JaGermanCar in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2003, 10:23
  4. Rattle?
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2003, 18:32
  5. Annoying Rattle
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2003, 22:15
