Volks AutosJMB Retrofits
    Oct 2012
    Warrington, North West
    986
    Help and guidance on removing my roof lining?
    Picking up a black roof lining up tomorrow, and just trying to weigh up how it all comes out?
    I know the A pillars just clip off, but what about the b and c?
    Is there any fixings in the roof I need to be careful of?
    Tay
    May 2012
    Warrington
    369
    Have never done this on an Audi, but I'd assume its a case of removing A,B and C pillars, interior lighting, sun visors and grab handles and possibly door seals to get access.
    Crunching The Gears
    Apr 2012
    Invergordon Scotland
    407
    Done it on mine for the crack, not much to it TBH.
    i started by taking off all the lights and grab handles, then the sun visor. Also the rear view mirror visor bit.
    then the a pillers clip off whech make the front of the roof easy to get to. When I took the C piller trim off I removed the boot trim on either side as it easier access, you also have to remove the long price In-between the C pillers these are held on with clips. This then gives you access to some torx screws which have to be removed before the main c piller can come off!
    Then the main roof would come loose after this, the tricky part is the sun visor clips
    thes are in two parts the outer bit comes off first which makes the main clips loose to come out.
    and the other bit is the main light peice in the middle there is a screw so it comes out.
    Hope that helps.
    Pictures make it easier so if I get a chance tomorrow ill get a guide made up.
    Mods so far...
    LED Interior Lights, Front splitter, Cruise Control.
    Puddle/ Footwell Lights, LED number plate and side lights.
    75% Window Tints, MY11 Lights, Black Optics Grill.
    MFSW, Leather trimmed Grab Handles. CH/LH Lights
    JL Audio, DAB radio
    Vinyl wrap wing mirrors
    Oct 2012
    986
    Cheers for that buddy, really appreciate it. Black roof lining really makes a great difference!
  1. sunroof and roof lining
    By tubby-ben in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2013, 10:43
  2. Roof Lining query! dye help
    By warrenlord in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th April 2011, 00:46
  3. A3 TDI Rear Bumper and Tow Bar Removal Help
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2008, 22:21
  4. S3 roof lining colour?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2006, 18:57
  5. V6 Torque??? (and centre silencer removal)
    By v6kev in forum Classic Audi Forum
    Last Post: 8th May 2006, 21:05
