Chris NottMonster Motorsport
Results 1 to 7 of 7
Thread: Airbag light...
    imported_Adambsmith
    Airbag light...
    is coming on whilst driving and then going off and then coming on and then going off etc.
    I assume a trip to the dealers is in order? [img]/ubbthreads/images/graemlins/book.gif[/img] [img]/ubbthreads/images/graemlins/woohoo.gif[/img]
    Sep 2005
    UK
    320
    Re: Airbag light...
    [ QUOTE ]
    [/ QUOTE ]
    A trip to the dealer ASAP - it is unlikely put a smack in the chops from an airbag would be unpleasant!
    Dec 2004
    Chester
    247
    Re: Airbag light...
    [ QUOTE ]
    [/ QUOTE ]
    Probably be something to do with the connection to the steering wheel, usualy is........
    mikep's Avatar
    Jun 2003
    Wetheringsett, Suffolk
    591
    Re: Airbag light...
    Have you taken a fuse out recently? I think.it's linked to the instrument cluster fuse. When we used to pull fuses to remap Golfs Mk4s and previous model A3s, we needed to pull the instrument cluster fuse, which caused the airbag light to trigger, so it was a quick reset with Vag-Com. But get it checked asap.
    Dec 2004
    Chester
    247
    Re: Airbag light...
    The electronic system on Porsche's after a steering wheel removal, used to put the airbag light on for around 20 start up's after a steering wheel removal occasion, after that it reset itself
    Mar 2004
    Newcastle, UK
    143
    Re: Airbag light...
    Had this on mine - was a faulty airbag unit aparently, although didn't get to find out which one.
    imported_ANNANBHOY
    Re: Airbag light...
    yeh i had this problem, they said it wont effect it all. got it fixed about 3 weeks after it came on !
