AH FabricationsBadger5
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By MrLapou
Thread: What mileage does my cambelt need changing at?
    May 2013
    Stafford
    56
    Follow john71482 On Twitter Visit john71482's Youtube Channel
    Question What mileage does my cambelt need changing at?
    I have a A3 TDI 2.0 what mileage do people think the cambelt needs replacing at, and is it better to get the cambelt replaced before adding mods?
    Jul 2013
    Cambridgeshire
    278
    Mine was done on £37k (or 5 years). The mileage was low for change, but I believe it was done on the time
    2007 A3 S Line Quattro 170 TDi
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    personally i had a cambelt fail on me 9k miles after change by audi (and currently in the progress of changing it at the worshop).. so if i were you id check it regularly like oil... piss easy to bolts to visually inspect it mate... as for change i would personally change it every 50-60,000kms ... dont not go by Audi's recommended 90,000km if not mistaken you loose your engine before you know it
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Rule of thumb 5yrs or 70k miles which ever is sooner.
    _G_ likes this.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Get the water pump done for the little extra mine has just had its second cambelt in less than 20k because the waterpump failed.. Little plastic impellers break and it chews itself.
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    It should say in the handbook, as there are different times for different 2.0TDI engines (PD and CR).
    There's been a lot of discussion on this in previous threads, but if you stick to the 70,000 miles or 5 years rule then you'll be fine.
    My handbook says 133,000 miles (215,000 km) for the 2.0 TDI common rail engine. I checked with Audi and they said 70,000 miles. When I questioned them about the fact that the book says one thing and they say another, they went off and contacted Audi. They came back and said yes, 133,000 miles is actually correct, they just use 70,000 miles for all models across the board. Obviously this will mean that some will be changed earlier than they need to, but they use the better safe than sorry method. Clearly money for the dealer has nothing to do with this.
    As it was, my water pump developed a leak at 71,000 miles so I ended up getting the belt changed then anyway.
    You'll probably find the belt is good for 133,000 miles, but the water pump isn't.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    May 2013
    Stafford
    56
    Cheers mine on 75,000 miles so need it doing!! What are prices like?
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    They're fixed prices for cars over 3 years old. It's £439 for a timing belt change, but you'd need to add the cost of the water pump to that as they don't mention it on the website.
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Did mine at 60k. Audi said they tested the water pump and it was fine.
    I did the 120k change myself and the water pump... it took me about 6 hours.
    Agree with MrLapou
    At this point I had decided not to keep any service history as I intend to keep it until it dies or perhaps resurrect it.
  1. 2003 Audi S3 - When does Cambelt need changing?
    By jimbo_50001 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2013, 22:41
  2. does the cambelt vibration damper need changing on bkd?
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2013, 15:34
  3. A4 cab 3.0 petrol-when does the cambelt need doing?
    By reggieroo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th July 2011, 03:17
  4. When does the cambelt need changing on a s3?
    By Tekin in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2008, 10:26
  5. Cambelt change what mileage?
    By TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th September 2005, 08:29
