Chris NottMonster Motorsport
Results 1 to 7 of 7
    Yonner's Avatar
    Feb 2009
    Oldham
    151
    Led lights fitted 2008 S3
    Just fitted the new led bulbs , took the yellow ones out as they look awfull,
    Here above is the DRL set to on and there very bright ,
    if I turn the dial to side lights manually the drl dim a little here is a pic
    Yonner's Avatar
    Feb 2009
    Oldham
    151
    Hey guys I have had 2 DRL bulbs go now , I think they may be overheating? I never keep them on all the time , occasionally I will just flick them on if its overcast , is there a way to adjust the brightness of them , if I can drop the brightness I think they will be fine because if I run with my sidelights I have no issues at all , but if I run the DRL on its own they will go within the hour , Any help appreciated
    Dec 2013
    68
    link for bulbs please
    TIA
    Y60 ADM's Avatar
    Jul 2013
    Hull
    Hello, what bulbs are they? I have been trying to find some bright ones for a long time now! Any help would be appreciated. Also do they work fine?
    Adam
    Yonner's Avatar
    Feb 2009
    Oldham
    151
    Quote Originally Posted by JaCkPoT View Post
    TIA
    POWERFUL CANBUS ERROR FREE DRL 1156 Ba15s 382 P21W BRAKE LIGHT REVERSE BULBS | eBay
    that's the bulbs I have fitted , I want the brightness setting like when I have the sidelights on at same time in the big picture above
    will these ones below be any better ?
    2x P21W 50W HIGH POWER CREE LED 1156 382 BA15s REVERSE BULBS AUDI DRL DAYTIME | eBay
    Jun 2011
    Wellingborough
    1,174
    The Cree's will be better.
    They shouldn't blow.
    I sell cree's to members here if you want to try mine out?
    Trups
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Yonner's Avatar
    Feb 2009
    Oldham
    151
    Do the Cree only come in 6000k mate ?
  1. Sportback LED Rear Lights (Fitted by itwasntme187)
    By chrisb72 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2014, 18:14
  2. Led Lights Fitted Pics Added
    By Customboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2012, 20:03
  3. LED tail lights fitted, dash light on
    By sam4191 in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st August 2009, 17:57
  4. Replies: 2
    Last Post: 18th September 2008, 10:19
  5. 2008 Audi A4 SE - No LED light option!
    By Kyoshi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th January 2008, 16:06
