JMB RetrofitsAH Fabrications
Like Tree1Likes
  • 1 Post By AjM
Thread: Automatic dsg gearbox problem - help !!
    Jul 2013
    Leicester
    13
    Hi need some advice or some knowledge from some asap .. Got an a3 2.0 t fsi with an auto box and come across a fault and need a help to see if someone knows before take it into a garage. Basically when selected drive and it goes into 1st the car kind of rolls as it should but them kind of judders like its going to stall. Then it's fine. It does it in reverse aswell. Not all the time but minority it does. Any ideas please?
    27,113
    What year is the car 1st?
    Calibrate with vcds, if still a problem, service the box.
    When was it last serviced?
    Jul 2013
    Leicester
    13
    It's 2008 and was serviced last at 109,000 now it's 117,000. But someone mentioned it may be the solinoide in gear 1. Sorry what does calibrate the vcds mean.
    AjM
    AjM's Avatar
    Living in Blissful Ignorance
    Jan 2007
    Torbay, S.Devon
    295
    I think he means when was the last time the dsg oil in the box was change, ideally it should be done every 40k miles, but more often than not it is not done at all!
    NHN likes this.
    Oct 2012
    Warrington, North West
    986
    Have a look on VCDS map see if a user local to you can scan your car and recalibrate the box as mentioned above
    27,113
    Yeap as the discussion was about the dsg, I did mean servicing of the box, not engine
  1. HELP.....A3 dsg gearbox problems
    By ian ditch in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2012, 12:22
  2. A4 2006 Auto Gearbox problem-Help!!
    By NAZZY in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th January 2012, 18:22
  3. Hi! New to audi-sport, Automatic A3 Gearbox problems.
    By Karl-g in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2011, 22:53
  4. 2.0 TDI DSG Gear problem Help!!!!!!!!!!
    By Spender in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2009, 22:43
  5. Possible Gearbox Problem Help Please
    By Kev12344 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th May 2009, 02:14
