Chris NottEM Tuning
Results 1 to 11 of 11
Like Tree4Likes
  • 2 Post By danb986
  • 1 Post By bez101
  • 1 Post By danb986
Thread: MOT question
    pwilliamson1991's Avatar
    Aug 2012
    UK
    76
    MOT question
    Hey I'm just wondering does anyone know the procedure for checking the fuel system during an MOT test?
    Basically wondering if a car "had" illegal fuel in it would there be any way of them telling or noticing via the emissions or anything?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,394
    What would you be thinking of fuel-wise?
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    I assume we're talking about diesel?
    Aren't diesels only tested for smoke anyway? I imagine poorer quality fuel will be more smokey, so that might be something to consider. Even supermarket fuels made my old remapped mk4 Golf smoke more.
    I'm not sure whether the emissions would be different or not, but regardless of that, I'd be more worried about the quality of it.
    I work for a construction machinery dealer and we get diesel delivered into our tanks for filling the machines, and even though the diesel is white (a lot of customers can only run on white) none of our engineers will touch the stuff for their new vans. Even Tier4 machines are a concern when it comes to quality.
    You'd need to consider sulphur and biofuel content.
    Still assuming it's diesel, if it's ever had red diesel in it in the past then the filters will be stained red. The MOT won't check this, but if you live in a very agricultural area and you are suspected then you could get checked by another agency.
    Red diesel has very high sulphur and will knacker a modern diesel engine, so any fines would be the least of your worries. A3's need ultra low suplhur diesel.
    If we're not talking about diesel (red or otherwise) then forget everything I've said above
    NHN and pwilliamson1991 like this.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,219
    No they don't test for red diesel... although it may or may not pass emissions
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    so ypu just told the forum your useing red ?
    LEE69 likes this.
    Aug 2012
    UK
    76
    "if a car "had" illegal fuel in it"
    Not my car in particular but a friends! but interested to know the story, and yea i was talking about red.
    Also another interesting fact I read was that the sulphur content of red diesel was actually reduced to
    10 milligrams of sulphur per kilogram of fuel to compared to 1000 mgs/kg back before 2011. So it is basically (or meant to be) sulphur free now
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    Nope won't get picked up or noticed.
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    Red is exactly the same as white apart from the dye
    We burn 1 litre of the stuff every 8 seconds in our brand new MTU marine engines. If it wasn't the same quality we wouldn't be able to use it due to warrantee issues
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Red isn't the same as white, but with dyes in it anymore. It used to be, but not now.
    Red isn't available as a proper ultra low sulphur diesel, which is why our new machines can't run on it. JCB, Isuzu and Cummins all issued warnings not to use red diesel in their Tier4 engines as it will cause damage and void any warranty. Any warranty claims have to be submitted with fuel samples and the old fuel filters to verify that red diesel hasn't been used.
    Surely they wouldn't go to all this bother if red and white were the same stuff.
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    You'd need to add expensive additives to this so called "Red ultra low sulphur diesel", to make it anywhere near the same as white ULSD, but in ensuring customers add the correct amount every time is impossible. This is why most engine manufacturers who have engines that comply with Tier4 emissions advise against using it. It'd also negate any financial benefits from using red diesel.
    I'm not sure what spec the marine engines are that you use, but the machine engines that have stopped using red are very low emission in order to comply with Boris Johnsons strict guidelines in central London and in underground tunnel applications such as CrossRail.
    pwilliamson1991 likes this.
    Aug 2012
    UK
    76
    Quote Originally Posted by danb986 View Post
    Always thought red was the exact same diesel only it had the red dye added :o
  1. MOT Question
    By psd99 in forum General Automotive Chat
    Last Post: 1st May 2013, 22:14
  2. MOT Question(rear foglight)
    By jojo in forum General Automotive Chat
    Last Post: 14th April 2010, 18:46
  3. MOT Question
    By Alba77 in forum General Automotive Chat
    Last Post: 16th February 2010, 20:51
  4. Cat and MOT emissions question - 1.8T 190
    By dope in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th November 2009, 17:28
  5. Couple of questions for admin...
    By MickHumphrey in forum General Chat
    Last Post: 2nd January 2003, 17:04
