Chris NottVolks Autos
Thread: vag com log
    Jun 2012
    barnsley south yorkshire
    32
    vag com log
    hi everyone
    i went to reset my sevice light and thought i would run a log while i was there and quite a few codes come up that i wasnt exspecting, the steering wheel one is ok because i havent got a bluetooth connected yet and the engine and airbag i know about them and was going to sort them in due time but the rest i wasnt exspecting and any help would be good because i dont know if any of them are serious and need to be looked at a.s.a.p
    Monday,29,July,2013,19:17:56:45888
    VCDS Version: Release 11.11.5
    Data version: 20121222
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 7D
    VIN: WAUZZZ8P65A072032 Mileage: 191780km/119166miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    37-Navigation -- Status: Not registered 0011
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC 0000SG 6337
    Revision: 12345678 Serial number: AUX7Z0D9FNI06W
    Coding: 0000072
    Shop #: WSC 01286 386 08256
    VCID: 6CD709E84F38B778ED4
    1 Fault Found:
    17058 - Cylinder 4 Glow Plug Circuit (Q13)
    P0674 - 000 - Electrical Fault
    Freeze Frame:
    RPM: 0 /min
    Torque: 226.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.32 V
    Bin. Bits: 00000000
    Temperature: -0.9°C
    Bin. Bits: 00110000
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0023174
    Shop #: WSC 06435 000 00000
    VCID: 3A7BFFB075ECD9C82F8
    No fault code found.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 G HW: 8P0 820 043 G
    Component: KlimavollautomatH12 0150
    Revision: 007962 Serial number: 8P0820043G
    Shop #: WSC 06314 000 00000
    VCID: 306FDD98A390139891C
    2 Faults Found:
    00483 - Control Module for Auxiliary Air Heater
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 100
    Mileage: 191780 km
    Time Indication: 0
    Freeze Frame:
    ON
    00797 - Sunlight Photo Sensor (G107)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H34 0301
    Revision: 00H34000 Serial number: 00000001145288
    Coding: 00884F06A214100000000000000000000000FE0F5C
    Shop #: WSC 00000 000 00000
    VCID: 3D71F4AC64C2EEF00AA
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 00000
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0011602
    VCID: 43858254022698007CE
    4 Faults Found:
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    001 - Upper Limit Exceeded - MIL ON
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
    011 - Open Circuit - MIL ON
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
    00588 - Airbag Igniter; Driver Side (N95)
    001 - Upper Limit Exceeded - Intermittent - MIL ON
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004012
    VCID: 4189885C183A8A106E2
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    2 Faults Found:
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    01301 - Control Module for Voice Recognition (J507)
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 P HW: 8P0 920 980 P
    Component: KOMBIINSTR. VDO H71 0210
    Revision: D03 Serial number: 2249DD03006098
    Coding: 0004408
    Shop #: WSC 00762 210 83614
    VCID: 4487814807289F38454
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500104A04010B
    Coding: 3D0F0B40070101
    VCID: 285F35F89B405B5849C
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 254
    Reset counter: 100
    Mileage: 182439 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 13:00:24
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D03 Serial number: AUX7Z0D9FNI06W
    1 Fault Found:
    01176 - Key
    008 - Implausible Signal - Intermittent
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H07 0220
    Revision: 0000013S Serial number: AUZBZ7MD215770
    Coding: 0209115
    Shop #: WSC 00994 211 10555
    VCID: 3467D18857882FB8F54
    4 Faults Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 135
    Mileage: 183001 km
    Time Indication: 0
    Date: 2013.03.26
    Time: 07:21:05
    Freeze Frame:
    Mileage: 191680 km
    Count: 2707
    Clock: 15:11
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 182439 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 13:06:48
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 182439 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 13:06:48
    02005 - Coding Pin
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 182439 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 13:06:56
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000048
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.10 1301
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 008000186D288505489AC63000
    VCID: F9F9A0BCB06A92D0E62
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H02 1301
    Part No: 1K0 907 719 B
    Component: Neigungssensor 004 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 E
    Coding: 0000048
    VCID: 3E73F3A069C4F5E8130
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209115
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 135
    Mileage: 183001 km
    Time Indication: 0
    Date: 2013.03.26
    Time: 07:21:05
    Freeze Frame:
    Mileage: 191680 km
    Count: 2707
    Clock: 15:11
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 182439 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 13:06:48
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 182439 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 13:06:48
    02005 - Coding Pin
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 182439 km
    Time Indication: 0
    Date: 2013.03.17
    Time: 13:06:56
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D51C4ECB4A27E70BAA
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    thanks for your help in advance
    ryan
    27,075
    Is this a smashed car repair?
    Jun 2012
    32
    hi nige
    it had a bump a long time ago thats the reason for the airbags the rest quite resently to be honest the only things i have had done to the car is had a new clutch last week and had rns-e fitted just short of 12 months ago, i have cleared all the codes and will give it a few days but just thought it was strange a whole list like that came up.
    Fossie
    Rhubarb Triangle
    3,969
    Looks like it !!
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
  1. Help understanding VAG-COm logs
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2010, 23:15
  2. Vag-com logging.
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2009, 21:26
  3. VAG-Com: Logs & Related
    By AJames in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th August 2009, 15:38
  4. help with vag-com log
    By vinceemmery in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th August 2009, 17:45
  5. How do I upload vag com logs?
    By Jay in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2009, 14:06
