Chris NottMonster Motorsport
Results 1 to 7 of 7
    Yolo_8p3's Avatar
    Jun 2013
    129
    Audi a3 1.6 tdi fuse box help!!
    As title says and to my previous thread my radiator fan isn't working now i don't know why but here is a pic of my fusebox
    Can anyone spot anything missing
    Or would someone with a 1.6 tdi pls post up a pic much appreciated for the help.
    Apr 2013
    Aberdeenshire
    595
    Does it run when you activate your ac it does look a bit empty though.
    Yolo_8p3's Avatar
    Jun 2013
    129
    Nope pal but it used to sent it to a garage who change the default headlights and bumper and now they don't seem to work wtf
    Apr 2013
    Aberdeenshire
    595
    Quote Originally Posted by Yolo_8p3 View Post
    Check the connections at the radiator and get a scan done someone local to you will probably help you out with vcds for beers
    what is the stray plug in the photo is it for drl s or something
    Yolo_8p3's Avatar
    Jun 2013
    129
    Quote Originally Posted by Chillout View Post
    wonder if something like that will come up on vcds?
    the panel was removed and re fitted the connecter was disconneted but plugged right back in after 20mins which i watched the fella do and i have re-checked the connector just seems like no pwer at all is there ?
    the cables you are correct for drls but need to get this sorted before i can take it to get coded
    Apr 2013
    Aberdeenshire
    595
    Check your manual for the fuse number and check it if you are in Aberdeen or surrounding I could could scan it for you
    Yolo_8p3's Avatar
    Jun 2013
    129
    Thanks dude much appreciated for the help
    Looked thru the manual couldn't find anything
  1. Audi 2.5 V6 TDI has Died!! Help
    By csmith in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th March 2010, 13:25
  2. 55 Pate Audi A4 2.0 TDI Turbo problem. HELP PLEASE!!!!
    By hronald88 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th September 2009, 19:04
  3. S4 fuse box help
    By OllyS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st May 2008, 12:17
  4. help on A6 fuse box
    By ricky80 in forum Classic Audi Forum
    Last Post: 12th May 2006, 23:16
  5. Audi A4 1.9 TDI 1996 Dashboard Display. Help!!
    By slips in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2004, 18:22
