Audi a3 1.6 tdi fuse box help!!
Yolo_8p3
NULL
As title says and to my previous thread my radiator fan isn't working now i don't know why but here is a pic of my fusebox
Can anyone spot anything missing
Or would someone with a 1.6 tdi pls post up a pic much appreciated for the help.
Nope pal but it used to sent it to a garage who change the default headlights and bumper and now they don't seem to work wtf:confused:
Check the connections at the radiator and get a scan done someone local to you will probably help you out with vcds for beers
what is the stray plug in the photo is it for drl s or something
wonder if something like that will come up on vcds?
the panel was removed and re fitted the connecter was disconneted but plugged right back in after 20mins which i watched the fella do and i have re-checked the connector just seems like no pwer at all is there ?
the cables you are correct for drls but need to get this sorted before i can take it to get coded
Check your manual for the fuse number and check it if you are in Aberdeen or surrounding I could could scan it for you
Thanks dude much appreciated for the help:confused:
Looked thru the manual couldn't find anything
D
10
644
Deleted member 172509
D
