Volks AutosMonster Motorsport
Results 1 to 29 of 29
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    I broke down :-(
    Hi all just broke down on a family trip :-( bad times.. Temp on the gauge went through the roof although the actual engine temp seemed fine fans cutting in and out etc.. Air con stopped being cold as well...
    Any ideas? No fault codes but when it got to 120 on the gauge a coolant warning popped up
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,199
    Lol ima point fingers at the map
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Quote Originally Posted by sliced View Post
    It's rude to point 😛
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    Did it throw coolant out from the reservoir as if its gets to those sort of temps it will spill out from the cap?
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    No coolant coming out which I why I don't think it 'actually' overheated
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,430
    water pump ?
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    water pump ?
    It's in my specialist today it looks very likely to be the culprit. Shredded itself great design using plastic :-(
    Lewis583's Avatar
    Mar 2010
    870
    When was the timing belt last changed?
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Just had a call from the garage, water pump had a few cracks in the impellers but not major :-/ they are putting a new pump in, seems when the cambelt was done at 58k they put a screwdriver through the coolant hose and that was leaking a little but not enough to cause major problems :-/ bit of a weird one will report back later, once they have tested it after the pumps in.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    It's a mystery! New water pump in and still overheating so its now back in bits working through individual bits of the cooling system.. :-/
    bez101's Avatar
    Jul 2008
    8,430
    so did it overheat or was it just the gauge playing up ?
    have you had the stat off and checked its not stuck closed ?
    or a failed CTS ?
    neither give codes all the time
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    or a failed CTS ?
    I think that's what the guys at the garage are doing next thermostat off to test..
    Personally I don't think it overheated
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    The saga continues! Soooo after a new water pump and cambelt and a new coolant hose as one was leaking slightly its still no better. It's had the alternator out 3 times now and it's sprung another leak from somewhere above the block.
    Mechanic thinks its the fans that arnt running properly so he is testing those.. It's becoming a headache now and he is also going to fit a new radiator as mine was leaking (which I knew about) this is going to be expensive
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    Sounds like you've got a lot of leaks on the coolant system? Couldn't be some dodgy coolant used in the past gunging things up and corroding others.
    Has it had a compression test?
    Jul 2013
    311
    Have you done a sniff test on coolant to check if the head gadgets gone ? Similar issues on a mk4 pd Tdi , also as graham said compression test it ! Is it building up lots if pressure in the cooling system ? Hoses ect ? Check your temp sensors in a hot cup of water plugged in still and see what they do to the temps on vag com
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Thanks gents just had some news.. Thermostat which was done 6 months ago so thought not to be the culprit isn't opening up much allowing only a trickle of coolant through.. So it's now stat, water pump, cambelt, radiator and one possibly two fans to get it put right.. Costly but as it wasn't me that did the cam and the water pump was on last legs anyway so preventative has got to be better than another bill learnt my lesson before on trying to take the cheap option.. So looks like we should be up and running soonish
    Apr 2013
    Aberdeenshire
    590
    If I ever put my car into a garage and they gave me a list of faulty components for a single I fault I would asking questions and I would also want the old parts but maybe that's me just being a d#%k
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Totally agree with you I know the guy quite well .. To be fair the water pump and belt have been bothering me just because it wasn't done by Audi it was the dealer non audi that sold it not saying they didn't do it but who knows. Radiator I knew about so its just the fans and the stat nice set of bills for the next owner!
    Apr 2013
    Aberdeenshire
    590
    The water pumps were a common issue I used to use the main dealer only with my passat but in a moment of madness I traded it for a 3.2 v6 with issues from a dodgy guy that shared a forecourt so he looked like a dealer but wasn't so any issues I have had I fixed them such as the radiator leaking at the ends as this is also common hopefully your sorted and you can get a lot of trouble free miles after your outlay.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Fingers crossed.. I'm looking to sell next year so although its done 79k its had all the work done so someone is going to get a well looked after motor
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    893
    Unusual for stat to close shut, they generally fail open.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    It's a fail safe thing for them to break open I heard, don't think it's totally shut just not totally open :-/
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    893
    Yes it is, whatever sounds like the problem
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Can't believe its failed after 6 months though.. I know they can be temperamental but that's ****e
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    893
    I know of a polo one that failed driving down the road after fitment.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Quote Originally Posted by LEE69 View Post
    I'm gonna be polo mint after this little number
  28. #27
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    893
    The hole in the middle might resemble the bank balance lol
  29. #28
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    Good luck sounds like the thermostat could be the culprit!
  30. #29
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Just to finish this thread off all is back to good! However.. New water pump, cambelt, radiator, coolant hose, thermostat and a repair to the aircon fan which wasn't working fairly cheap fix :-/!!!!! Thanks for your help guys
  1. Broke down, engine overheated
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th April 2010, 21:45
  2. Car broke down this morning......:(
    By Gooner in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st February 2010, 21:24
  3. Totally gutted, my S3 broke down. Possibly Cambelt wreckage...
    By Dennis Moeller in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2009, 10:34
  4. tdi broke down already
    By bonerp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2007, 20:46
  5. My TDi has broke down, help.....
    By Drizz in forum Diesel forum
    Last Post: 31st December 2006, 16:05
