Monster MotorsportChris Nott
    May 2013
    10
    Done my first Mod and found more than I expected
    I've just changed the A3's interior lamp to the Ambient / map reading lamp and all went well, well apart from one of the screws making a run for it and I spent 10mins looking under the seats to trying to find it again!
    Anyway, my car doesn't have the MFSW (something I'll look at changing later) and when I've tried to connect my phone, Bluetooth has never been found. Now when I've taken the old interior lamp out I found the microphones are fitted and the wiring loom is all connected up to them. So I don't know if its all there and not switched on or if only part of it is or where the Bluetooth module should be if it is there.
    My car, which is a 59 plate, does seem to throw up more questions the more I look into things with it. The dealer says its on the end of the chassis run before they switched to the 2010 model so has a mixture of the two.
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    634
    Im pretty sure what you seen there is the interior sensor for the alarm.
    May 2013
    10
    Quote Originally Posted by SL11 CKK View Post
    That's answered that question, just looked to see what the sensors look like and that's them. I knew someone on here would know
    27,024
    If you didn't have a mic connected to the trim that's has the light reflectors inside, that you have to remove to remove the light assembly, then there's no mic in there.
    We supply/fit mfsw & BT systems if interested
    May 2013
    10
    Thanks for that, I've just sent PM with details
  1. FIRST MOD DONE!!!
    By benclothier in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2013, 17:15
  2. More NHN modding and a clear wrap.
    By Adamantium in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th October 2012, 23:56
  3. Got my A3 and did my first mod!
    By smudge_don in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2009, 22:54
  4. First Victoria Cross for more than 20 years.
    By imported_Adambsmith in forum General Chat
    Last Post: 18th March 2005, 23:19
  5. How do i add more than one pic at a time
    By concoursneil in forum General Chat
    Last Post: 28th June 2004, 21:37
