AH FabricationsEM Tuning
Results 1 to 9 of 9
Thread: What clutch??
    yuleys3's Avatar
    Jul 2011
    53
    What clutch??
    I need a new clutch as it slipping in 4/5/6 sometimes 3rd at around 4k+ revs. I'm running JBS custom code stage 1, I was thinking a helix stage 1 clutch and luk DMF. Is that suffice or is there any you'd recommend? Thanks lads
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,457
    Hi there id get a spec stage 3 or a loba stage 2 ..
    Pushing the limits..
    Jan 2011
    Australia
    1,224
    Add Sevv on Facebook
    Quote Originally Posted by RS3-KEL View Post
    +1 to what he said... get LOBA set it and forget it mate...
    yuleys3's Avatar
    Jul 2011
    53
    What are the SMF like for gear change, town driving and engine noise? Don't want anything too heavy on the foot really.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,783
    Quote Originally Posted by yuleys3 View Post
    None of these are particularly heavy,and will feel maybe slightly heavier than the stock clutch.
    You will get more thrash at idle but not when moving.
    Personally,I wouldn't recommend a Spec Stg 3 clutch as this is a paddle type clutch and they are often a pain in stop-start driving.
    If you choose a Spec,then the Stg2+ would be fine.....mine is a Spec Stg3+ which is way more than you'd need,but both the 2+ and the 3+ are full face clutches,i.e. not made from a series of paddles.
    yuleys3's Avatar
    Jul 2011
    53
    Quote Originally Posted by S3Alex View Post
    Cheers Alex think I'm gonna go for your first bit of advice the sachs and luk DMF as I'm only planning of going as far as stage 2 at some point. Cheers bud
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,783
    The only warning with the Sachs is to give it a good few hundred miles of running in before booting it.
    If you treat it badly in that period,it won't last well......drag style starts also are a no-no.
    I had a Sachs until Stg4 came along,meaning it held onto 440lbs before giving in,and that's well above it's rating of 400lbs.
    yuleys3's Avatar
    Jul 2011
    53
    Changed my mind after reading many thread sim gonna go for the sachs loba.. Cheers lads
    Jan 2009
    124
    I just went with the Loba SMF combination and i'm liking it. It has a higher biting point than the standard clutch and makes a fair bit of noise on idle. The biggest difference is the bite you get in each gear, pulls really well and doesn't feel soft like the standard clutch.
    S3 Revo Stage 2+
    Milltek Non Res-ITG-Autotech HPFP-Loba SMF
  1. what clutch?
    By danclarke in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2007, 20:27
  2. What clutch / hydraulic fluid ?
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2007, 19:47
  3. what clutch
    By alan_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2007, 21:46
  4. what clutch type do you have?
    By dummi in forum Tuning
    Last Post: 8th February 2006, 21:35
  5. What clutch?
    By imported_velcrobix in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2005, 10:19
