Badger5JMB Retrofits
Results 1 to 7 of 7
    Cardiff, United Kingdom
    390
    Air con troubles
    At the start of the recent warm weather I started using my air con for the first time since I bought my car, a 2008 sport back. The problem I had was that it blows hot like a hair dryer for 40-45 min and then cools down to what would feel like a standard desk fan, no icy coldness just a fan really.
    I took it to my local garage who drained and refilled it but it was still the same, I took it back today (2weeks later) and they did the same again, they said they both over and under filled it but still no joy. It's just the same, hot air then just a fan.
    Ive run a scan through my VCDS and there's no fault that I would accociate with it, it shows I have a prob with my boot light and radio but also that I need to change a spark plug.
    Any ideas what could cause this?
    Thanks in advance....
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    634
    Is your compressor clicking? Ideally you want to get it checked over by an A/C specialist.
    Apr 2013
    Aberdeenshire
    590
    [QUOTE=welshwoody;1931069]At the start of the recent warm weather I started using my air con for the first time since I bought my car, a 2008 sport back. The problem I had was that it blows hot like a hair dryer for 40-45 min and then cools down to what would feel like a standard desk fan, no icy coldness just a fan really.
    Thanks in advance....[/QUOTE
    Does your clutch engage and if so do you have condensation forming on the suction pipe (largest pipe) also is your air flow ok and not restricted due to a dirty pollen filter and are your vent fans at full tilt
    390
    I've had the bonet open when it's running and there's no clicking, the vents blow air fully, where is the large pipe I'd be looking for? The pollen filter was changed about 6 months ago at my cars service if that's the one behind the glove box? How would I check if the clutch engadges?
    thank you
    Apr 2013
    Aberdeenshire
    590
    When your clutch is disengaged only the outer pulley runs ,when it engaged the center spins the suction pipe runs from the evaporator under the dash back to the compressor you will see it come through into the engine bay an run to the compressor also if your vent fans are not running at a high enough speed you compressor will disengage to stop liquid returning to the compressor as you can't compress a liquid.
    coxy8329's Avatar
    Nov 2011
    Hampshire
    166
    VCDS I believe the aircon system pressure can be seen in the measuring blocks, can't remember which ones. But it will show a pressure change if the compressor is working. Clearer than listening for the clutch or watching pulleys and belts.
    With the aircon switched on the discharge and suction pipes will be different temperatures. Note be careful because one will get very hot the other very cold if it's working correctly.
    Audi A3 Sline 170 2.0 TDI
    Mods Done
    RNS-E mkII fitted, Tinted Repeaters, Center Armrest,
    LED Interior Lights, Cruise Control, LED Number Plate Lights,
    VW fan windshield washers, S3 Pedals, Metal Footrest,
    DPF & EGR delete, Unicorn Remap, De-badged the tailgate.
    With DPF Without DPF
    Apr 2013
    Aberdeenshire
    590
    If you know any fridge engineers in your area they could check it as many garages don't have a clue it's a bit far for me to travel though you could have a number of issues choked drier,compressor not pumping,clutch with an excessive gap ,faulty expansion valve condenser fans not running causing it to trip on hp.
  1. A4 B6 Air-Con Blower Troubles
    By wallacr in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd June 2008, 16:27
  2. Air con gas
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2004, 08:01
  3. 1.8 T Sport, Noisy Air-con ????
    By jiffi77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2004, 14:23
  4. Hissing Air con A4 1.8 T
    By hendyc04 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th April 2004, 18:46
  5. Air con cleaner???
    By stumunro in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2003, 13:56
