    Oct 2012
    65
    Idle stabilisation injector timing
    Hi guys I've got the rough idle problem, I've searched on here and followed various how to's like the cambelt timings and tick over but still seem to have the rough idle!
    before I decide its the dmf I'm trying to check the injectors!
    Could anyone tell me if these readings are out?
    cylinder 1 -0.35 Cylinder 2 -0.40 Cylinder 3 0.38 Cylinder 4 0.40
    that's with warm engine
    Car is 2.0tdi 2007 42000
    cheers in advance
    26,716
    Intake manifold flap ok?
    Injector readings afaik are within tolerance.
    Oct 2012
    65
    I thought the tolerances were within 0.5+/-?
    intake flap?
    26,716
    & your tolerances are within 0.5 according to your data.
    Intake manifold flap that the air intake goes through, it opens & closes, sometimes, engine/year dependent, the teeth inside these break & the unit doesn't work properly, could be a restriction in air flow, speculative as diagnosing over the net, but something to check.
    Oct 2012
    65
    Yeh sorry my fault didn't read it properly!
    Is it easy to access and check? Not the best with diesels and this engine done most my work on petrols and Leon Cupra r.
    was going to look see if injectors seals looked ok but weren't obvious without cracking tools out and we were going out tonight ha
  1. 2007 Audi A3 170 TDI Quattro idle problem? Injector Recall done.
    By davsmith64 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2013, 12:14
  2. a3 2.0 tdi 2004 8p shudder on idle when warm, timing???
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2011, 23:12
  3. How to adjust rough idle and camshaft timing on VW and Audi TDI pumpe duse engine
    By PhilW in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th May 2011, 18:57
  4. 2.0 TFSI - lumpy/ uneven idle after Timing Belt service & underboost fault!!!
    By akash_sky1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th April 2010, 22:27
  5. injector on time?
    By dultanur in forum VCDS (formerly VAG-COM) forum
    Last Post: 31st October 2006, 16:36
