Badger5AH Fabrications
Results 1 to 20 of 20
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    Oil temperature display on S3
    I was just wondering, im one of them people who religiously lives by warm up and cool down, especially after my last car was prone to piston problems standard and mine was stage 3
    anyway, I was just wondering if there was a way to get the oil temperature display in the speedos to stay on, when you selected "oil temperature", it stays on for like 30 seconds then goes back to the menu, is there a way to keep it on constantly?
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    Not that i'm aware of.
    Bullys3's Avatar
    Mar 2013
    Scarborough
    191
    How do you get the oil temp up on your speedo?
    Mar 2013
    Leicestershire
    425
    Quote Originally Posted by Bullys3 View Post
    if you flick through your menu, you'll come to a screen that says "check", go into that and oil/oil temperature is there. Sorry its a bit vague I'm trying to remember off the top of my head. If you can't find it let me know and ill go out and get the full sequence.
    Bullys3's Avatar
    Mar 2013
    Scarborough
    191
    I think I know what you mean pal ill work it out cheers
    RYes3's Avatar
    Apr 2012
    Cheshire
    730
    I wanted this when I had my S3, only available on the "RS3 Boost Menu" though..... so I bought an RS3 lol
    2012 RS3 Ibis White | Black Styling Pack | Black Roof Rails | Bose | Cruise | Tyre Package | Privacy Glass
    Mar 2013
    Leicestershire
    425
    Quote Originally Posted by RYes3 View Post
    thats a expensive way around it, misses wouldn't be too pleased though. I wonder if she'd buy it if I told her I just spent £30,000 to display oil temperature... Lol
    Bullys3's Avatar
    Mar 2013
    Scarborough
    191
    Cheaper to fit gauges for them all a tad less than £30000+
    Jul 2013
    311
    i just live by the same rules i always have , let the coolant get upto temp as the oil will be near enough the same , and then when shutting down do a few miles slow or gentle driving and then get home knock it off if you can hear any ticking then just knock it back on for 5 mins
    Bullys3's Avatar
    Mar 2013
    Scarborough
    191
    Yes I do the same always warm up and cool down any turbo charged car
    May 2012
    RETFORD, NOTTS
    1,753
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Bullys3's Avatar
    Mar 2013
    Scarborough
    191
    They are good just really expensive
    Aug 2006
    126
    buy a scan gauge, you can display 4 things at once and plugs into the OBD2 port
    Bullys3's Avatar
    Mar 2013
    Scarborough
    191
    Where they from how much ? I'm wanting to put a boost gauge in anyway
    Aug 2006
    126
    Aug 2006
    126
    The ScanGaugeII can display up to 4 of 12 possible data parameters at one time:
    * Fuel Economy
    * Fuel Rate
    * Battery Voltage
    * Coolant Temperature
    * Intake Air Temperature
    * Engine Speed (RPM)
    * Vehicle Speed (MPH and KM/H)
    * Manifold Pressure (only if available on your vehicle)
    * Engine Load
    * Throttle Position
    * Ignition Timing
    * Open/Closed Loop
    Feb 2013
    262
    Quote Originally Posted by s3_sid View Post
    the oil won't be near enough the same
    Audi S3 : revo stage 2+
    Dean_T's Avatar
    May 2004
    West Mids
    523
    Quote Originally Posted by R34nel View Post
    I'm glad you bumped this thread as I was going to post on here and forgot!
    There can be massive discrepancies between water/coolant temp and oil temp - the other day I waited for coolant to hit 90 and then checked oil temp, it was only 50.
    Wouldnt mind an easy to read guage fitted as its a bit stupid of Audi to make the oil temp only show for a short amount if time but then again for the average joe that isnt going to remap or treat the car properly they probably dont care.
    Dean.
    turbonutz's Avatar
    Jul 2013
    Glasgow
    400
    wish i could afford to do that
    Sep 2012
    10
    Driving home from work today I found a way to keep the reading up once it's there. Press the up/down switch at the end of the stalk before the 30 seconds is up to refresh the counter. I know this isn't really a fix and probably isn't much use but I thought it worth mentioning because I haven't seen it mentioned before.
  1. S3 DIS Oil Temperature show "---C" ???
    By Gizmo306 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd September 2007, 15:30
  2. Faulty oil temperature guage
    By Ben_yo in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2006, 17:30
  3. Outside Temperature Display Sensor - Where is it?
    By coajt in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2005, 19:01
  4. Temperature Display Accuracy
    By jonathanA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2004, 20:21
