Sky InsuranceBadger5
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By TDI140
Thread: Number plate bulbs out cant fix even with standard bulbs, been pulled 3 times now ???
    TDI140's Avatar
    May 2011
    1,355
    Help i cant get them to work ive been pulled over 3 times now and havnt a clue how to make them work again do i need to delete error code via vag com as no thread ive searched clearly tells me what to do
    urgently need help
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    Have you checked if a fuse had blown?
    TDI140's Avatar
    May 2011
    1,355
    Yes checked but all interior lights and external lights are working
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,217
    Put in new led canbus ones, disconnect battery wait a bit reconect it, should work.
    Driving without rear number plate lights isn't actually as bait as you think, when a cars behind you it's headlamps light up the number plate
    edit: nvm just read the bit about police, just put new ones in then disconnect battery wait then reconnect, for me I didn't have vagcom and originals won't work at all
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Mar 2011
    Cleveland
    983
    Make sure every contact face is scrupulously clean.
    sliced's Avatar
    Jun 2012
    1,217
    Oh yea make sure it's the correct way round! And make sure the prongs are connecting to it
    TDI140's Avatar
    May 2011
    1,355
    Whats correct way round ? The bulbs ? There the same both sides,
    ill take earth off the battery and wait couple minutes see if it fixes it, got an annoying light on the dash keeps coming and going butbulbs aren't working at all,
    Also connections are squeaky clean i even went and took all the boot lid apart to see if everything is connected and there was no breaks in wires there as well
    sliced's Avatar
    Jun 2012
    1,217
    Hi mate after my led ones went out, I couldn't get original bulbs to work no matter how long the battery was disconnected for etc, if you got vagcom you should be able to delete the codes and the originals will work.
    If you have a new set of LED festoons, fit them disconnect the battery then reconnect it after a while. I believe the led lights only work one way as its positive and negative sides to it but I could be mistaken.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,856
    Yeah they can be tricky to get working after an error! I found it takes a bit of perseverance and plenty of key out, doors locked\unlocked action to clear the fault.
    & yes, as said, the Canbus led's are polarity sensitive
    2009 A3 SB 2.0T DSG S line
    TDI140's Avatar
    May 2011
    1,355
    Theres few people who have original LED audi ones on there cars from the audi a5 does anyone know part number of them ? Ill go audi and get a set also get new bulb holders just incase they are rust or connections are bad, ill try battery today later on see if it does the trick
    TDI140's Avatar
    May 2011
    1,355
    Just ordered these from audi will they plug and play work straight away ?
    Feb 2011
    Plymouth
    1,141
    Part numbers:
    4H0 943 021
    4H0 943 022
    They will plug and play and look beautiful too, got them on mine
    TDI140's Avatar
    May 2011
    1,355
    Exactly the same ones ive just ordered from tps, ill fit them and have codes cleared via vag com and hopefully that does the trick :-/
    sliced likes this.
    sliced's Avatar
    Jun 2012
    1,217
    Let us kno how it goes
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    310
    Yes they can be a nightmare to get sorted. When I changed mine for LED's they didn't work for ages. Then all of the sudden they started to work and been fine ever since. Good luck sorting it.
  1. Number plate light out
    By zseano in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd November 2011, 16:12
  2. Replies: 2
    Last Post: 14th December 2010, 10:16
  3. Anyone had problem with number plate light lens cracking/breaking?
    By jaymarwa in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd November 2005, 18:18
  4. Fixing Rear Number Plate
    By imported_gek in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 14:09
  5. How are number plates fixed to the bumpers?
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th December 2003, 09:23
