Volks AutosSky Insurance
Page 1 of 3 123 LastLast
Results 1 to 40 of 88
Like Tree6Likes
Thread: Which lowering springs to go for?
    theo289's Avatar
    Oct 2012
    Bristol
    179
    Hi All,
    Have an Audi A3 sportback 2007 with 18's RS6 reps - at the moment when i hit any kind of bump/ little bit in the road, my rear wheels are rubbing really badly. So now i'm at the stage of thinking about replacing the springs as there has been a lot of discussions on here about this - but which is best - H&R or Eibach?
    H&R Sport Lowered Spring Kits - Demon Tweeks - H&R
    Eibach Pro-Kit Lowering Spring Kit - Demon Tweeks - Eibach
    If anyone has any pictures/ comments on the ride, the response of the car with corners etc would be great.
    Appriciate all of your help as usual
    Feb 2011
    Plymouth
    1,139
    Got the H&R's, they feel better than standard however as you'd expect with anything thats lowered it bounces slightly. Doesnt really go low enough on the front, but i like hardly any arch gaps. all in all, very good and i'd reccomend.
    what offset are your wheels and have you removed the rear screws in the bumper?
    Jul 2013
    44
    Just bought myself some H&R. Reading the forums and a lot of searches they seem a better ride that the Eibachs.
    Fitting this week so will try get some pics.
    TDI140's Avatar
    May 2011
    1,350
    Sell you my H&R 55mm springs for £100 if i buy some coilovers soon if your interested in collecting frim derbyshire PM me
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    TDI140's Avatar
    May 2011
    1,350
    Only been on car for about 6 months
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    ^^^Good deal, good springs
    TDI140 likes this.
    ....................I'll make a build thread one day.
    theo289's Avatar
    Oct 2012
    Bristol
    179
    Quote Originally Posted by smurfworth View Post
    Got a feeling they are 8J 245 18. Just looking for a reasonable ride which doesn't cause rubbing (which is what I currently have - and lots of it!)
    theo289's Avatar
    Oct 2012
    Bristol
    179
    Quote Originally Posted by TDI140 View Post
    check the inbox
    Feb 2011
    Plymouth
    1,139
    245's will rub like a ***** if lowered, you can just about get away with 225's on H&R's. any lower and you need to look at 205's or 215 to stretch them inside the arches. Also depends on your offset which will either be ET 45 or ET38
    g dawg likes this.
    theo289's Avatar
    Oct 2012
    Bristol
    179
    Okay so if I go for 225, does it cause much rubbing?
    Thanks for the advise so far
    TDI140's Avatar
    May 2011
    1,350
    Ive got bentleys ET41 9J running 225/35/19 only rubs with 5 people otherwise its fine recommend 215's to avoid any rubbing
    theo289's Avatar
    Oct 2012
    Bristol
    179
    as the current suspension on my car is stupidly spongy, if I were to have four people in the car, that causes rubbing. Do you find if you have four it causes rubbing too?
    thanks
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Here are some before and after shots of mine on H&R 55's:
    Before:
    After:
    Ride is a bit harder, handles a hell of a lot better in the corners. Much more fun to drive now. Very happy with the drop.
    theo289's Avatar
    Oct 2012
    Bristol
    179
    Quote Originally Posted by MTRL View Post
    Before:
    After:
    They look very good! How is the ride? What size are your alloys?
    TDI140's Avatar
    May 2011
    1,350
    No rubbing with four and my wheels are wide as a mofo ! As most people know bentley rims stick outside the wheel arches on an a3 with 5 theres some rubbing not bad though four i havnt noticed any rubbing at all
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    Absolutely....I have 245x40x18s on mine,and it required a suspension rebuild to fit the lot under the car.
    Otherwise you need to resort to arch bending and silly amounts of camber.
    This will give you an idea of what it looks like....
    And what it took to get them under the arches......
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Quote Originally Posted by theo289 View Post
    Alloys are 18" x 8J. ET 45.
    Running 225/40/18
    Ride is absolutely fine, its defiantly firmer.
    No problems with speed humps, no rubbing. Not had more than 2 people in the car yet though so cant comment on what its like with a full car, but I try to avoid having more than 2 people in there anyway. Scuffing up my mats with their feet, get the bus.
    I don't imagine there will be a problem.
    Beagles's Avatar
    Apr 2012
    Cornwall
    88
    Running 225/40/18
    I hate passengers as they are just messy and also ruin my mats!
    I have 18 RS4 reps, 225 40 18's and I think Et45 and it scrubs like a B***h on the back, screws removed too!!! Is pretty low though:/ ImageUploadedByTapatalk1375031352.036068.jpg
    Can kinda see how low it is in this. I'm on coilovers though!
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    theo289's Avatar
    Oct 2012
    Bristol
    179
    I've just spoken to a company called Performance 3000 in Yeovil and they are saying that if the car rubs a bit here or there, the ride would rub even more with 35mm H&R springs - so confused now
    Feb 2011
    Plymouth
    1,139
    YOU CANNOT RUN 245 TYRES WITHOUT RUBBING
    Clearer now?
    maximum of 225 width, with a maximum offset (ET) of 45. so, you cant run et38 offset alloys without rubbing.
    Lowering your current setup will make it rub like nuts.
    change your tyres before lows.
    /thread
    theo289's Avatar
    Oct 2012
    Bristol
    179
    Clearer now?
    /thread
    sorry for any confusion but im on 225/40/18
    Feb 2011
    Plymouth
    1,139
    right, what alloys do you have? any spacers? do you know the offset of them?
    theo289's Avatar
    Oct 2012
    Bristol
    179
    unsure of the offset but they are replica RS6 alloys
    theo289's Avatar
    Oct 2012
    Bristol
    179
    18's
    Feb 2011
    Plymouth
    1,139
    then its gotta be a real low offset, my guess is et38.
    see mines on 225/40/18 8J, offset of 45 and on 50mm H&R springs, can have a full car and not one bit of rubbing occurs. The wheel can be so far up in the arch that the arches are inline with the top of the alloy and still absolutely nothing rubs.
  28. #27
    theo289's Avatar
    Oct 2012
    Bristol
    179
    will need to try and measure it but in essence the car just touches the inner wheel arch lining - i want the 35mm drop
  29. #28
    theo289's Avatar
    Oct 2012
    Bristol
    179
    8J ET 45
  30. #29
    theo289's Avatar
    Oct 2012
    Bristol
    179
    everythings all done - spoke to Damian and ordered the H&R Springs
    Pics to follow!
    MTRL and Jonse like this.
  31. #30
    Jonse's Avatar
    Oct 2012
    376
    Looking forward to seeing the result
  32. #31
    Jul 2013
    44
    Just fitted my H&R's tonight, quick drive round the block tonight to check them over and seem good quality.
    Smooth ride at speed, slightly harsher on bumpy surface at slow speeds, no worse than S Line springs, saying that I did have a broken rear so clunk has also gone.
    Looking forward to testing them on way to work in morning.
  33. #32
    theo289's Avatar
    Oct 2012
    Bristol
    179
    Quote Originally Posted by Dan_Mol View Post
    Sounds positive so far do you have any images?
  34. #33
    Jul 2013
    44
    No pics yet, was dark and wet outside when got finished, will snap one at dinner today. Sits better just need to choose the right wheels to fill the arch.
    Don't think you will be dissapointed with the H&R. Ride was fine coming to work this morning, haven't had chance to push it but overall impressions are good.
  35. #34
    theo289's Avatar
    Oct 2012
    Bristol
    179
    Did you go for the 35 or 45/55mm drop?
  36. #35
    theo289's Avatar
    Oct 2012
    Bristol
    179
    Okay so the springs are now on! first of all you can notice the difference on the rear and front of the car where it has dropped slightly - pretty nice stance and rather subtle!
    Ride:
    Well i'm quite a difficult to please guy however motorway driving - perfect, couldn't ask for more!
    City Driving: i am quite lucky to have been able to have driven the car immediately after collecting it from Bristol straight to Beckenham in London and London city driving; its not too bad, a little harsh and a few rubbs here or there but overall its not too bad!
    I will have to wait till next weekend when i am camping and have a car full of crap.
    Will put pictures up tomorrow once i have given the beauty a little clean
    Thanks all!
    Jonse likes this.
  37. #36
    theo289's Avatar
    Oct 2012
    Bristol
    179
    As promised here are all of the photos:
    Before lowering:
    After lowering:
    i have had quite a bit more rubbing so thinking of removing the inner linings of the rear wheel arches
    wish you all luck
  38. #37
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Jesus, removing the arch linings is quite drastic. You shouldn't be getting any rubbing, you can remove the arch lining screw to see if that helps first.
    Also, looking at the before ride height I don't see how that would rub unless you are carting around a grand piano. Perhaps its a different issue.
    You have a side on shot of the new stance?
  39. #38
    BoutTime's Avatar
    Apr 2013
    Trowbridge
    91
    Have you fitted spacers as they look fairly flush with the arches?
    After 3 BMWs in over 13 years, I'm giving Audi a go.
  40. #39
    BoutTime's Avatar
    Apr 2013
    Trowbridge
    91
    Forget that last question. I guess they're a different offset being RS6 replicas.
  41. #40
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    601
    You sure it is the wheel rubbing and not the belly tray on the square speed bumps? You shouldn't be rubbing unless you haven't removed the arch screw.
  1. Which lowering springs b7 cab
    By Marco_b7cab in forum DPM Performance
    Last Post: 31st May 2013, 08:47
  2. Replies: 0
    Last Post: 3rd August 2009, 10:56
  3. which lowering springs?
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2009, 21:01
  4. My H+R 50mm lowering springs will be for sale soon....
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th November 2008, 14:16
  5. Which lowering springs for 2000 S3?
    By ScottandJo in forum Tuning
    Last Post: 14th November 2008, 12:45
