Badger5JMB Retrofits
    Mar 2012
    Wiltshire, UK
    10
    Popping rear brake lights every 2-4 weeks
    Hi Chaps,
    I have had an ongoing problem where I seem to be popping my rear brake light bulbs on an ever more frequent basis. To begin with it was once every 3 months, but now it has warmed up I am getting through them every 2-4 weeks!
    Currently buying these from Halfords at £2.99 for a pair: Halfords (HBU382) 21W Car Bulbs x 2
    Do you guys reckon these are just shoddy quality bulbs, am I braking too hard (joke ), or is there maybe an underlying electrical fault which is causing too much current to flow to the bulbs causing them to have such short lifespans?
    Today I was driving through town just near halfords with my rear right brakelight out (has been out for about 1 week) then my rear left one went too! Thankfully I was only a few corners away from halfords and managed to wack in a new pair before anything bad happened.
    Any advice is much appreciated!
    Car info:
    2006 Audi A3 Sport 2.0 TDI 3door with the older style rear light cluster (pre 2008 facelift).
    Kind Regards,
    Alec
    Oct 2012
    Aldershot, Hampshire
    190
    It does sound abit dodgy. I used to have a motorbike that loved blowing its right headlight every week or so. But there was nothing wrong with wiring. Volts or amps. If you put a amp meter on it and test the watts. Amps and voltage you may just be able to get away with updating the bolt to fit with the readings
    crazylegscrane's Avatar
    May 2008
    London
    156
    My wife's A3 2.0 TDI has an appetite for brake light bulbs as well - seems to be the rear right all the time
    S3 Sept 08 to.....
    A3 2.0 TDI Sport April 04 - May 08
  1. B7 Avant rear brake light bulb
    By landylout in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th July 2007, 08:54
  2. Rear brake light constantly on...
    By AudiNick in forum General Technical / How To
    Last Post: 29th December 2006, 11:37
  3. Changing rear brake light
    By hardeep1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th December 2006, 10:47
  4. Front Signal and Rear Brake Light Errors
    By vpg_ii in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th December 2004, 05:34
  5. Rear Brake Light DIS warning
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2004, 17:19
