Cambelt or Chain?
CCZ engine in my 2009 2.0 TFSI car has chain.
Reactions: Artimus
I have the same CCZA engine & it'd be nice to know for definite. Are you certain, as I read elsewhere that some engines have both Chain & Belt?
Edit: it seems you're correct - just checked on another forum. :)
The car i'm looking at or should i say i've just bought :D is an Audi A£ 2.0 FSI Sport
Congratulations. :icon_thumright:
It's a non-Turbo then? What year is it?
Reactions: tally2425
Pretty sure there's the Cambelt that you replace and is connected to the crankshaft, then there's a camchain which connects the two cams together.
As above, your 2004 A3 2.0 FSi non turbo has both a timing belt and a timing chain.
Belt from Crankshaft - waterpump - camshaft
and
Chain from exhaust cam to inlet cam.
Only the belt is a service item that should be changed at a set interval (60-75,000miles (depends on who you ask) or 5 years). The chain only needs changing if you are experiencing problems with it.
