Chris NottEM Tuning
    Jan 2005
    Colchester, Essex
    147
    S3 - KO4 Turbo inlet dimension?
    I've been searching for quite some while, trying to find what size silicone coupler I need to come of the turbo for my CAI. I think it's 51mm off the turbo?
    But measuring the oem pipe that came off it seems larger? Anyone any idea.
    Bullys3's Avatar
    Mar 2013
    Scarborough
    185
    Surely the oem pipe is the right size
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    I think you're probably measuring the outside of one and inside of the other but the internal diameter of the OEM pipe is the correct size.
    Jan 2005
    Colchester, Essex
    147
    Yeah the internal diameter of the OEM pipe is of course the right size, it's just such an a*se to measure as it's soft convoluted rubber. Using my vernier it measures 56-58mm diameter with the hose clip off. What threw me was the fact that when searching the web I keep seeing refs to 51mm diameter. So wondered if anyone had the 'official' dimensions. Or had replaced their silicone coupler on their CAI so knew what size to get.
    In short i'm going to be best to take my existing silicone coupler off and measure it.
  1. Ko4 turbo inlet, heater pipes in the way????
    By phil miller in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd October 2012, 15:36
  2. nuespeed Turbo inlet pipe
    By kenny_boon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th July 2006, 14:53
  3. KO4 Turbo on 98 A4
    By PhilR in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2006, 23:00
  4. Turbo inlet pipe for s-line (190bhp)
    Last Post: 24th February 2006, 17:34
  5. Age old question..... Turbo Inlets on 1.8T
    By cclarke184 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2004, 07:14
