EM TuningChris Nott
    May 2012
    32
    Rear camber adjustment seized
    Hi
    I've got a 2003 2.0 TDI Sport to which the previous owner has fitted 18" wheels and had the car lowered slightly (think he said 10mm). The camber was adjusted when the work was done but it's a few years later and I'm guessing the suspension has bedded in further as I've noticed that the rear wheels are wearing more on the inside. I took the car to a 4 wheel laser alignment place and they confirmed that the camber was slightly out on the rear wheels but even before he got the car on the ramp he told me they often find that the rear camber adjustment bolts are seized on A3s of my car's age. That turned out to be exactly the case as he couldn't shift the bolts and told me I'd have to take it to a garage before they could adjust it.
    I wondered whether anyone else with a similar aged car had come across this issue, I've no idea what would need to be replaced whether they could just do the bushes or I'd need completely new lower arms. I'm just trying to work out whether I'm better off getting it fixed or if I should just accept that I'm going to have to replace the rear tyres more frequently. The price of the tyres doesn't make that a particularly appealing prospect though :-\
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Quote Originally Posted by StewMang View Post
    Hi
    10mm is virtually nothing in terms of lowering and the effect it would have on camber. Unless your doing mega miles I would just leave it and if needed rotate the rear tyres to even up the wear on the edges.
    Have you actually tried lubricating the bolts with something like plus gas, wd or liquid wrench? Can work wonders.
    May 2012
    32
    Quote Originally Posted by TimG View Post
    It may have been more then 10mm but he said it was within the range the S3 is lowered to. Whether it's the lowering or something else that's caused it, the camber is definitely out (by equal amounts on each side) and while I could rotate the tyres the inside wear is pronounced enough that I'd rather get it sorted.
    I haven't tried lubricating the bolts, hadn't considered it to be honest, they looked well and truly corroded so I assumed the only option would be to replace them. I'll buy some of the stuff you mentioned though and see if it makes a difference, thanks for the advice/
  1. 8L A3 Rear Camber Adjustment??
    By deeman88 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2012, 16:18
  2. S4 rear camber adjustment....
    By cfoster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th March 2011, 12:41
  3. Rear tie arms/Camber Adjustment Product
    By Dave_Bayern in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th August 2007, 15:24
  4. Rear Camber Problem Adjustable bush kit!!!
    By 242spot in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2006, 21:31
  5. Adjusting Rear Camber / Toe on S3 !
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2006, 21:43
