Monster MotorsportChris Nott
Thread: N75 issue?
    slepy's Avatar
    No Audi but still here
    Sep 2009
    Sheffield
    1,116
    N75 issue?
    Hi all.
    I have some running issues with my leon 2.0 tdi 170 PD. It is difficult to accellerate smoothly in 1st and 2nd gear and overall car feels "jerky. Couple of days ago it went to limp mode when I floored it. Scanned it with vcds and it has an error
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 DT HW: 03G 906 018 DT
    Component: R4 2.0l PPD1.2 G 0431
    Revision: --H42--- Serial number: SEZ7Z0G3824196
    Coding: 0050072
    Shop #: WSC 04941 785 00200
    VCID: 7AF103AB357F40C86EF
    1 Fault Found:
    000665 - Boost Pressure Regulation
    P0299 - 006 - Control Range Not Reached - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 39
    Date: 2000.00.00
    Time: 05:44:48
    Freeze Frame:
    RPM: 2944 /min
    Torque: 344.0 Nm
    Speed: 101.0 km/h
    92.04 %
    Voltage: 14.46 V
    Pressure: 2449.5 mbar
    Pressure: 1959.6 mbar
    Readiness: N/A
    I checked all the hoses going from/to N75 valve and cant find anything wrong with them. Pressure actuator seems to move smoothly enough as well. I also did run a test with vcds on the n75 output.
    Does anyone know what values should it read? Shouldn't N75 make a clicking noise during the test?
    Anything else I should check?
    1999 Audi A4 1.8TQS - track car project</a>
    2007 Seat Altea 1.9Tdi
    May 2012
    RETFORD, NOTTS
    1,748
    Saw the same fault code today on a 2007 A4, but it wasnt picking up fast, turbo pressure wasnt making the requested untill late up in the rev range.
    Going to try the N75 and possibly map sensor.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    slepy's Avatar
    Sep 2009
    Sheffield
    1,116
    That's the thing, mine doesn't lack any power. It still goes well but the issue is when you accelerate smoothly especially noticeable in first and 2nd gear. Do you think it might be inlet manifold actuator related? Been going through loads of forums with similar issues and it seems it does help in some cases. I can see some "oil" on the actuator rod itself but not sure how else I can check if it works properly. It isn't easy to get to it and although actuator itself is just few quid, it will be a manifold off job to change it. I would at the same time clean the EGR valve though.
    May 2012
    RETFORD, NOTTS
    1,748
    Not sure about your fault symptoms, but N75 replaced and no more faults for me :D
    slepy's Avatar
    Sep 2009
    Sheffield
    1,116
    Ehh. I will clean the egr, replace the actuator and see if it helps. If not, n75 will be next. Bloody cars!
  1. N75 AGU Issue
    By Yohan87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2013, 19:11
  2. VAG-COM Log - Boost Issue 2.5TDi - N75?
    By AlexGSi2000 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st February 2012, 12:38
  3. Boost/N75 issue??
    By audi_a3_turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2011, 21:16
  4. Lambda replaced, N75 issues?
    By teambeer in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th March 2007, 09:30
  5. N75 Race Valve
    By S3DBW in forum General Technical / How To
    Last Post: 22nd July 2003, 12:29
