EM TuningBadger5
    Mar 2008
    52
    Audi A3 1.9tdi limp mode at high revs
    Bought from a garage and the problem started happening just after 3 months of owning the car (about a week after the warranty ran out - sods law). In 1st, 2nd and 3rd gear the car pulls just fine, every now and then I get a little stutter, like I have taken my foot off the accelerator and put it back on quickly. If I hit a duel carriageway/motorway and floor it after changing to 4th, it will go into limp mode around 65mph. If I change to 5th gear at 2500 revs (55-60mph, to prevent the limp mode in 4th) and floor it in 5th, as soon as it gets near 70mph it will go into limp mode. I currently get round this problem by bouncing the accelerator in 4th and 5th.
    I'm was fairly sure it was sticky vanes so took it to a vag specialist garage who charged me £120 for clean the turbo out with chemicals (probably the £50 kit from eBay plus labour). Tested the car after I picked it up and the problem went away, a week later and the problem returned, £120 down the drain.
    Now for the flaming.
    I changed the air filter to a K&N. Pointless on a diesel I know.
    I installed a chip from tdi-tuning. Cost me £120. I was happy to pay more than the cheap chinese ones from eBay as I believe they cause more harm than good. With the chip on or off the car has the same limp mode problem.
    Unsure whether these points are relevant but it always helps to know the history.
    Car has 105000 miles on the clock.
    Where do I go from here?
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Scan it with VCDS to confirm if you have any codes related to sticking turbo vanes problem (Overboost codes).
    Apparently best fix is to either strip the turbo and then clean it or replace it with a new/refurbished unit.
    I'd go back to the garage who charged £120 and complain that the issue returned within a week.
    VCDS USER
    27,083
    The turbo cleaner is temporary at best & if its a VNT unit, then it needs removing & cleaning properly or it will just come back time & time again & eventually blow up.
    Scan the car & show us the logs 1st, probably show us overboost errors.
    Also, fitting a tuning tool when you have engine limp issues is not a good idea, fix the problem 1st before buying tuning mods & the K&N is pointless, its a 1.9TDI, it wont make any difference imho.
    May 2012
    RETFORD, NOTTS
    1,753
    3 months warranty means nothing when your consumer rights allow 6 months from time of sale to challenge the cars condition. remove the mods and return it for them to inspect and fix under the sale of goods act.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. bought my first audi, brought it home and wallop! limp mode...
    By kenney valhalla in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th October 2011, 12:59
  2. 1997 Audi a3 1.9tdi gone limp UPDATE
    By pirateshairyfairy in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2011, 17:29
  3. 1997 Audi a3 1.9tdi gone limp
    Last Post: 19th January 2011, 22:11
  4. 2000 X 1.9tdi AJM Engine Limp Mode / Lumpy / smokey / Poss Injector
    By alictait in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th January 2011, 13:52
  5. Replies: 4
    Last Post: 15th January 2011, 13:51
