ThisIf no one replied in an open thread, what makes you think they will go to the hassle of creating a new PM.
I have a 1.6fsi mate
what faults do you have?
It is gutless, but not as gutless as that - I'm fairly sure we established your wife's 1.6 is the 8v not the FSI, since it has a cambelt.Isn't the biggest problem the fact that it feels like there isnt a turbo fitted??................... Thats certainly the case with my wifes one.
Faults -
Clutch judder esp in reverse and esp when cold.
Weird jerky throttle response on a constant throttle - eg constant 35mph in 4th gear or in slow moving traffic - it's impossible to make smooth progress in a traffic jam in 1st/2nd gear without slipping the clutch.
Intermittent minor misfire at idle - can't see any pattern - happens hot/cold long/short trips all weathers.
Car has done 84K with FSH - has had the cam chain changed under warranty when younger (I assume for the rattle of death - which it still does very occasionally, again with no apparent pattern).
-Clutch judder happens on mine too, not really a fault more of a characteristic, not too bothered about it, just got to be abit more carefull when its cold.
- not sure about making smooth progress issue, maybe try cleaning the throttle body.
- misfire at idle, happens on mine to, but is more noticable when holding the car on the foot brake. probably something i should look into.
Hope this puts your mind at ease.
I have a 1.6FSI
The judder in reverse also happens with mine but not an issue TBH
Slow traffic at 5-10MPH is a PITA 1st gear power surges so not smooth and 2nd gear riding the clutch can't be good.
Mine is rapid though
