Volks AutosJMB Retrofits
Results 1 to 10 of 10
    Yolo_8p3's Avatar
    Jun 2013
    129
    Fan isn`t working please help!!
    ok so i need some advice my fan isn`t working its a a3 2011 1.6 tdi the full rad pack was removed and refitted and before i disconnected the fan pack they were fine but now since re-plugging them back in its(only 1 big fan)not working at all and even though the temp is still on normal its getting pretty hot under there...
    any ideas what to check?
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    561
    Diesel fans take years to kick in if your just letting it stand ticking over,one works on engine temp the other works with the aircon,but i cant remember if when you put the aircon on if they both jump in to action,without been stupid how do you know its not kicking in and do you know what point it kicked in before ? we have to leave them running for hours to get the temps up in diesels and even taking them a run you'll struggle to get them to over heat,maybe take it for a run get temps up and then let it stand ticking over but this again isnt that good for the car neither.
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    Yolo_8p3's Avatar
    Jun 2013
    129
    Quote Originally Posted by phil76 View Post
    i picked the car up from garage yesterday and drove like 22miles home the temp didnt go over half but when i got back home to check the water and oil under the bonnet was extremly hot and you could barely touch the plastic cover of the engine so then i tried my ac button and the fan wasnt still working weird how i only have 1 large fan ?
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    561
    Cars do get warm under the bonnet mate ,but if the temprature is normally around 90 for normal driving if it starts going above 95 etc thats when the fan should kick in,i dont know how many fans it should have but i thought they all had two from memory but i am probably wrong ,is the aircon working ? i would ring up and just mention your concerns maybe ?
    Yolo_8p3's Avatar
    Jun 2013
    129
    Cars do get warm under the bonnet mate ,but if the temprature is normally around 90 for normal driving if it starts going above 95 etc that's when the fan should kick in,i dont know how many fans it should have but i thought they all had two from memory but i am probably wrong ,is the aircon working ? i would ring up and just mention your concerns maybe ?
    cos its a 1.6 tdi i assume that's why its got 1 fan but the fact that it was really really warm under there gets me a bit worried that i may cause damage cos of the fan not kicking in and when the car is running the fan used to work immediately but now its nothing
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    In nearly five years of ownership my fan never kicked in even on hot days and after long drives. Mind you it's 2.0 TDI.
    VCDS USER
    Yolo_8p3's Avatar
    Jun 2013
    129
    I just need to check it's all working then I can sleep at night :thumbup:
    Does anyone know where the thermostat plug is cos if I loop that it should work
    Yolo_8p3's Avatar
    Jun 2013
    129
    does anybody know where the fan switch is on the a3?
    and if i loop the plug the fan essentially should come on right?
    Yolo_8p3's Avatar
    Jun 2013
    129
    Still need help of anyone can it would be appreciated all I need to know is where the fan temp switch is located??
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by Yolo_8p3 View Post
    try running your a/c and see if it runs failing that try and get a scan done.
  1. Sat nav plus system not working please help.
    By daveturbo in forum Satellite Navigation
    Last Post: 9th March 2012, 11:34
  2. Roof Windows Mirrors NOT working ?? please help
    By pompeyclements in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th January 2012, 22:57
  3. A4 Cab - Roof stopped working! Please help!
    By wywywywy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2010, 21:03
  4. A3 Passenger windows not working please help!
    By EvoFQ400 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2009, 08:15
  5. intrior lighting not working.. dash not working.. please help
    By patrick swayze in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2007, 12:16
