AH FabricationsChris Nott
Results 1 to 14 of 14
Like Tree5Likes
  • 1 Post By JamesS4cab
  • 1 Post By A3SBQ
  • 2 Post By Muzza80
Thread: P3 Integrated Boost Gauge
    ahitchkins's Avatar
    Jan 2013
    Worcestershire
    58
    anyone on here running the P3 Cars Vent Boost Gauge on a S3?
    P3Cars Vent Integrated Digital Interface - A3/TT Mk2 > Interior > S3 8P/Mk2 > AUDI A3/S3 > VAG Specialists > PSI Tuning - VW Specialists
    if so what are your reviews and photo links would be shweet
    Ibis White S3 8P
    Mods; Forge Twintake - Forge Highflow Dumpvalve
    Bullys3's Avatar
    Mar 2013
    Scarborough
    185
    I'm wanting a vented boost gauge but not a digital gauge not sure what I need to get it done though
    ahitchkins's Avatar
    Jan 2013
    Worcestershire
    58
    Quote Originally Posted by Bullys3 View Post
    i must admit i'm not a fan of boost gauges but that one looks pretty sweet
    Ibis White S3 8P
    Bullys3's Avatar
    Mar 2013
    Scarborough
    185
    Every turbo charged car should have a boost gauge from manufacturer in my eyes its good for piece of mind you know when you've got no boost on your dial that there is a problem
    A3 SportBack 2TFSI quattro DSG
    Jul 2009
    Norway
    220
    I have it. It is brilliant.
    Shows you boost, coolant temp, intake temp, oil temp, ignition, speed, 0-60 and battery voltage.
    It is the best solution out there for our cars.
    The best is it looks totally OEM.
    Photos you see on there wep page.
    It is super easy to install
    Best regards
    J$B
    Norway
    Jul 2011
    216
    Any pics of the install you done on your car a3sbq.
    Jun 2010
    217
    Any pics?!
    JamesS4cab's Avatar
    Mar 2008
    1,091
    This is mine (excuse the blurred picture!)
    S3_Jacko likes this.
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    Jul 2009
    Norway
    220
    Hi. Sorry for the delay.
    Ment to post but been busy travelling at work and getting married.
    So here you have some photos of my instal. Pretty mutch strait forward to do.
    Best regards
    J$B
    Norway
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    Quote Originally Posted by JamesS4cab View Post
    This 1 looks sweet.... I was just looking at this 1 tonight aswell... priced it up.... looks kinda oem as far as that goes, love the white dials and sweep
    Oct 2012
    171
    Quote Originally Posted by S3_Jacko View Post
    Works well with Defi Racer in white as well, if your feeling a little flush in the pocket, doesn't half take some dremel work on the silver vent ring to fit properly. There is a great deskmonkey guide on vagoc for this, I followed it to the letter and it worked a treat.
    JamesS4cab's Avatar
    Mar 2008
    1,091
    That would be mine Mat.
    S3_Mat likes this.
    Dean_T's Avatar
    May 2004
    West Mids
    511
    Like this a lot - it would be perfect if I could buy it with a digital oil temp built in too - do they do them like that?
    Dean.
    Muzza80's Avatar
    Oct 2013
    Glasgow
    338
    This p3 integrated digital gauge works through the diagnostic port and while it looks very nice it is ultimately very expensive for what it is and the accuracy should be questioned. Many of the readings are a calculated guess made up from readings of a number of sensors on the car, simply not comparable to a proper dedicated mechanical gauge set.
    People want to see boost because it's constantly changing and looks cool, ok I get that but really your important readings on a tuned forced induction car are oil temp, oil pressure and I'd probably argue that the most important of all would be your fuelling through a wideband AFR gauge with a dedicated wideband lambda fitted into the downpipe.
    If you want a much cheaper way of replicating what you get with the p3 integrated gauge set then get yourself a bluetooth OBD2 dongle and buy the Torque app for your Androud phone or tablet and a suitable removable dash/windscreen mount, this sill display everything and a lot more that the P3 one does, the gauges are fully customisable and the dongle costs about £10, the app about £5 and then ideally a 7" tablet if you have one, I use my Google Nexus 7 and it's ideal.
    Another nice option is the Depo Racing Multi Gauge which gives you mechanical boost, true oil temp, oil pressure and voltage all in the one gauge. I think it comes with all the specific sensors you need (for the oil temp and pressure) and this could be adapted for any car I'm sure.
    Dean_T and S. like this.
  1. Zada Tech dashboard integrated clock and boost gauge.
    By vrbob in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2012, 18:11
  2. boost gauge
    By dwarfslapper in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2004, 23:44
  3. Boost gauge to an S3
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2004, 19:21
  4. boost gauge ?
    By jimboA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2003, 23:18
  5. Digital boost gauge
    By Mo-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2003, 23:42
