Chris NottSky Insurance
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By JohnE
  • 1 Post By Mikemc
Thread: what stereo can i change this for
    tdi-man's Avatar
    Jul 2009
    1,612
    just wondering what head unit I can change this for ?
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    TDI140's Avatar
    May 2011
    1,364
    I hate mine aswel any minor scratch on cd it stops working
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Mar 2012
    369
    Without wanting to be a smart arse, it depends how much work/expense you want to go to. I changed mine for an aftermarket single Din unit, but it wasn't a five minute job and it needed some extra wiring and a canbus interface.
    Mattyj6969 likes this.
    Oct 2012
    Warrington, North West
    986
    Depends on budget, you could do a double din conversion, and go for rnse? And if rant confident in your own work guys like NHN will sort you out
    Persian's Avatar
    CEO
    Sep 2012
    186
    keeping oem clean look? then would recommend getting the double din fitted the actual cage should be about £20-40 as I saw on eBay and either a concert/rnse radio depending on budget. Concert will cost you about £40-100 depending on condition and rnse over £400 I assume.
    Wirings would be easy if I have dealt with audio/in car entertainment before if not with a bit of guide and help should be easy enough.
    Apart from that you could of course to for a single din aftermarket unit! I personally love oem.
    tdi-man's Avatar
    Jul 2009
    1,612
    cool may go for rnse at some point then will keep an I open for cage
    Mar 2012
    369
    Don't wish to rain on your parade, but it's more than just a cage - you need to resite that switch panel and climate - quickest and cleanest way to do that is by using the double-din parts - do a search on double-din if that's the way you want to go.
    Oct 2012
    986
    I converted my dash to double in under 3 hours. I still need a bit of trim to finish it off but not fussed at the minute just waiting for one to pop up on eBay
    tdi-man likes this.
  1. can i change this panel?
    By sarahcocker1989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2012, 19:32
  2. Could someone confirm what they can see in this video? (Turbo related)
    By jackpilk in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2012, 23:33
  3. What rims can i get for my ride
    By tick in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2005, 09:29
  4. Cruise control upgrade - What models can have this done?
    By simong in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd May 2005, 17:42
  5. What car is this for Kamei grill
    By Altern8 in forum General Chat
    Last Post: 1st August 2003, 09:23
